Lanceautoman Posted April 17, 2018 Share Posted April 17, 2018 Bit hard to explain in words, but, I have today received an H4 Led bulb kit to fit to my existing headlamp. The bulbs are 3 sided, like a toblorone. Does anyone one know if the bulb should be fitted with the triangle pointing to the ground or the sky? Quote Link to comment Share on other sites More sharing options...
JRH Posted April 17, 2018 Share Posted April 17, 2018 The H4 base plate should ensure it goes into the housing the correct way. Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 17, 2018 Author Share Posted April 17, 2018 The base comes off to enable the bulb to be seated properly so it is not possible to tell which way it should go in unfortunately Quote Link to comment Share on other sites More sharing options...
Phill Posted April 17, 2018 Share Posted April 17, 2018 I'm thinking about getting LED front lights for my ybr, since the normal lights aren't powerful enough and I can't put 55w/60w car bulbs since it'll melt the plastic reflector... where did you buy them from? How will the electrical system will cope? Do you need modifications? Might swap the rear light aswell for a led.Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fozzie Posted April 17, 2018 Share Posted April 17, 2018 Supposedly they are a direct replacement (according to the ones I've seen on eBay). LED's generally use bugger all power, these do use more but generally no where near conventional bulbs. I'd line the bike up about 3-5 meters from a wall, and use masking tape to draw a line of the beam pattern. Then keeping the bike in the same position, fit the LED bulb and compare, just turn the bulb around on its base until you get the right pattern (It can never flick up towards the right side of the beam as this will dazzle other road users). Adjust the height with the adjustment screws as normal. Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 17, 2018 Author Share Posted April 17, 2018 I'm thinking about getting LED front lights for my ybr, since the normal lights aren't powerful enough and I can't put 55w/60w car bulbs since it'll melt the plastic reflector... where did you buy them from? How will the electrical system will cope? Do you need modifications? Might swap the rear light aswell for a led.Sent from my SM-G950F using Tapatalk I did have this installed: https://www.ebay.co.uk/itm/Osram-HS1-Night-Racer-90-Motorbike-Headlight-Bulb-90-Brighter-64185NR9-01B-/352052517738?clk_rvr_id=1502418937181&utm_medium=cpc&utm_source=twenga&utm_campaign=twenga&utm_param=eyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwM2UzNmQwOGQ0NjM0ZmQ0ZGQ5MDk5Yzk2NzNjM2YxYyIsImkiOiIzNTIwNTI1MTc3MzgiLCJ0cyI6MTUyMzk3NTU1MSwidiI6Mywic28iOjE1MDAsImMiOjE3NDA2MH0%3D&rmvSB=trueMuch brighter than standard. No modification required. The reason i have changed is that i have recently fitted heated grips and ive replaced almost all bulbs on the bike with LEDs so the alternator / battery do not burn out. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted April 17, 2018 Share Posted April 17, 2018 Not a bad idea to keep the electrical system at the same balance as it was previous to the grips, but don't worry about the alternator. They are rated to handle more than is required as manufacturers expect you to run heated equipment and satnavs off the electrical system. You could likely have a heated vest, gloves, satnav, and phone charger on the go and you'd not get anywhere near overloading it Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 17, 2018 Author Share Posted April 17, 2018 Not with a YBR 125 mate. I have Oxford Smart grips and prior to my LED overhaul the charging warning light would come on when idling with the heaters on. Now the light never comes on. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 17, 2018 Share Posted April 17, 2018 Not with a YBR 125 mate. I have Oxford Smart grips and prior to my LED overhaul the charging warning light would come on when idling with the heaters on. Now the light never comes on. Plus some small, shit bikes (like mine) have generators. Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted April 17, 2018 Share Posted April 17, 2018 Hi, the stock bulb for the YBR is a HS1 which is a 35w x 35w bulb, I'm not sure the housing will allow a H4 to be fitted.This might be of use https://uk.video.search.yahoo.com/search/video?p=headlight+bulb+yamaha+ybr+125&fr=yhs-invalid#id=2&vid=0167f3cbdeec51c66580a2331b111331&action=view Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 18, 2018 Author Share Posted April 18, 2018 All sorted now thanks all - I messed around and have fitted it. The beam pattern, whilst not as clean as a halogen one, is not too bad. the light out put is superb. I went for a ride at 10pm last night down some dark twisties and the light output is as not far off the xenons on my Jag. Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted April 18, 2018 Share Posted April 18, 2018 You may find it fails the MOT with the LED bulb fitted, just a heads up you might want to swap it over when it's due. Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 18, 2018 Author Share Posted April 18, 2018 cheers - MOT just been done but i agree, may need swapping prior to next one. Although by then i hope to have an MT-07! Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 18, 2018 Share Posted April 18, 2018 Have you got a link to what you used? Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 20, 2018 Author Share Posted April 20, 2018 https://www.wish.com/product/59eee1c659843432e8cf5fd8 Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted April 21, 2018 Share Posted April 21, 2018 That is a grade A shit site. Won't let me browse without signing in, so disable Java script to stop pop up, you can not browse this site without Java script enabled. Well f**k you then Quote Link to comment Share on other sites More sharing options...
