Matti2314 Posted May 27, 2018 Share Posted May 27, 2018 I’m having a problem with my Honda cbf 125 2013 model.When driving my bike it dies after like 1 minute of driving in parkinglot speed, no power at all. I turn the ignition off, and wait for 1 minute and turn the ignition on again and it starts. When the bike dies there is no power at all, no lights or dashboard lights.When the bike is ideling it somtimes revs up to 3000 rpm and engine light turns on. After like 2 seconds it goes back to normal and engine light turns off.I have no clue what the problem is, i have tryed taking out the carburator to see if there was any dirt in there, but it was clean Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 27, 2018 Share Posted May 27, 2018 Try sandpapering the contact surfaces of your battery terminals then make sure the bolts are firmly tightened. Might be as simple as that . By the way, why are you fiddling with the carburetor when this is quite clearly an electrical problem ? Quote Link to comment Share on other sites More sharing options...
Matti2314 Posted May 27, 2018 Author Share Posted May 27, 2018 I found the problem, a wire to the ignition was losing connetion when turning the handel bars. Thanks for the help Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted June 1, 2018 Share Posted June 1, 2018 Why's your CBF got a carburettor ? I think that's your problem Oh I see you've fixed it, well done Quote Link to comment Share on other sites More sharing options...
