richardgtr1400 Posted May 27, 2018 Share Posted May 27, 2018 Anyone had a problem with a Kawasaki GTR1400 repeatedly blowing the regulator rectifier?I'm onto my third regulator/rectifier in 18 months.The first time it failed I had a fluctuating voltage and flickering headlights (intermittent) followed by sudden complete power failure (blew main fuse).Second one lasted 15 months and then the voltage started to fluctuate again and flickering headlights. Voltage would go up to 15.5 and down to 10v. Got it replaced (and new battery), but voltage continued to fluctuate (up to 16 and down to 10v). Went up to 16v especially if the battery was put on trickle charge overnight but if not on trickle charge would at best get 13.5 v. Last week was in slow traffic (so low revs) and the voltage kept dropping (down to 9v) until the computer screen turned off. Battery completely discharged. Jump started it to get home and was OK, but voltage continued to fluctuate, but not dropping below 12v even at low revs. Taken the charging system to bits. I've checked the stator - does what the service manual says it should (56v per lead at 4000 rpm), battery is new, starter motor relay is working properly. Regulator / rectifier failed again on multimeter testing. Anyone got any ideas as to why this is happening? Could it be a fault in the main relay box - which is the only thing I haven't been able to check because one way screens prevent removal to check - has another starter relay in it?Thanks in anticipationRichard Quote Link to comment Share on other sites More sharing options...
TimR Posted May 27, 2018 Share Posted May 27, 2018 Check battery earth leads on both ends .You can buy a one way screw removal bit ( security bit set ) Were these regs / recs new or second hand ? Gtr1400 forum is a good place http://www.gtr1400.co.uk/forums/index.php( have a 2017 model) Quote Link to comment Share on other sites More sharing options...
megawatt Posted May 27, 2018 Share Posted May 27, 2018 Try an aftermarket regrec. Quote Link to comment Share on other sites More sharing options...
richardgtr1400 Posted May 27, 2018 Author Share Posted May 27, 2018 Thanks Tim and MegawattTim I'm being a bit dense here. When you say check battery earth leads on both ends, can you explain a bit more what you mean? Both of the replacement reg/recs were new - aftermarket ones. I'm going to try a second hand original in case that works better.Will try the GTR forum! Thanks for the advice both Quote Link to comment Share on other sites More sharing options...
TimR Posted May 27, 2018 Share Posted May 27, 2018 Thanks Tim and MegawattTim I'm being a bit dense here. When you say check battery earth leads on both ends, can you explain a bit more what you mean? Both of the replacement reg/recs were new - aftermarket ones. I'm going to try a second hand original in case that works better.Will try the GTR forum! Thanks for the advice both Earth lead connection to frame and engine can cause issues if not a clean connection Quote Link to comment Share on other sites More sharing options...
megawatt Posted May 27, 2018 Share Posted May 27, 2018 Try a genuine Kawasaki regrec? Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 28, 2018 Share Posted May 28, 2018 The thing with aftermarket rec / regs or anything else for that matter is that just because you pay £30 - £50 for one it doesn't mean that it isn't a £13.99 marked up to make you believe its of superior quality. There is a reputable brand called Electrex available in the UK that I believe often exceed the manufacturers specs. Quote Link to comment Share on other sites More sharing options...
