Wolfgang Posted June 2, 2018 Share Posted June 2, 2018 Any advice would be greatly appreciated!I split my fuel pipe yesterday so I replaced it with some pipe from a bike shop although it was thinner the guy assured me it would be ok. Today on a ride my bike stopped like it had run out of fuel, on closer inspection the pipe had kinked twice quite bad and the fuel wasn’t getting through.I’ve replaced it was a thicker pipe just although is still a kink in the pipe.I can’t see how I can get around this especially due to the angle of the to ends the pipe connects.How do I fix this or will it be ok with a small kink? Thanks Quote Link to comment Share on other sites More sharing options...
TimR Posted June 2, 2018 Share Posted June 2, 2018 Have you routed it correctly ?Some fuel pipes have an external wire spring like sheath that prevents kinks or its internally built . Quote Link to comment Share on other sites More sharing options...
Six30 Posted June 2, 2018 Share Posted June 2, 2018 Errm .... get the correct bit of pipe Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted June 2, 2018 Share Posted June 2, 2018 Quote Link to comment Share on other sites More sharing options...
Wolfgang Posted June 2, 2018 Author Share Posted June 2, 2018 Errm .... get the correct bit of pipe Haha thanksI thought asking a motorbike mechanic would see me right but guess not. I’ve order one off eBay hopefully it does the trick cheers Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 2, 2018 Share Posted June 2, 2018 Have you routed it correctly ?Some fuel pipes have an external wire spring like sheath that prevents kinks or its internally built . Like mine , you haven't left the spring type bit off have you ? Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 2, 2018 Share Posted June 2, 2018 I'd avoid this new fangled transparent green fuel pipe , it goes rock hard after a few weeks , I don't like it . Like Six says , probably best to buy the correct part , its probably pre shaped rather than just a length of tubing. Quote Link to comment Share on other sites More sharing options...
