Beans Posted June 16, 2018 Share Posted June 16, 2018 Any ideas? On my cbf1000, within the last week, the front nearside indicator has stopped working and the rear has started flashing really quickly. Definitely not the front bulb and I don't think it is the connections to the front. I know that the front worked and the rear flashed normally last week because a friend was showing me what to check, POWDERSS.Any help gratefully received Quote Link to comment Share on other sites More sharing options...
Hoggs Posted June 16, 2018 Share Posted June 16, 2018 The rear will be flashing quicker due to the front not working less resistance in the system more power to the rear faster flashing. I'm not sure about why the front isn't working if you've replaced the bulb... relay maybe? Quote Link to comment Share on other sites More sharing options...
Beans Posted June 16, 2018 Author Share Posted June 16, 2018 Ah ok. Thanks for the quick response hoggs Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted June 16, 2018 Share Posted June 16, 2018 If the bulb is ok its either got no feed or no earth.Use a multi meter to check it out.Front mini indicators on my FZR were forever packing up from bad connections in the bulb holder. Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 16, 2018 Share Posted June 16, 2018 (edited) Swap the bulbs to see if the good bulb works in the front and vice versa, maybe its a duff bulb , can you see if the filament is broken ? By the way its a good thing it flashes faster if one bulb is gone because the indicator warning light on the dash also flashes faster so you know that other road users can't see you indicating. Could be a life saver . Edited June 16, 2018 by fastbob Quote Link to comment Share on other sites More sharing options...
Beans Posted June 16, 2018 Author Share Posted June 16, 2018 Filament is fine that's why I don't think it is the bulb, but yes bob I could confirm that way. Quote Link to comment Share on other sites More sharing options...
Beans Posted June 17, 2018 Author Share Posted June 17, 2018 Halfords at 10 for a 2 pack of indicator bulbs and maybe even a cheap multimeter. No idea how to use the latter but maybe this is the start of my tech education. Stand by! Quote Link to comment Share on other sites More sharing options...
rennie Posted June 17, 2018 Share Posted June 17, 2018 If the lamp is ok it will be a bad connection or bad earth Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted June 17, 2018 Share Posted June 17, 2018 Do a google of ‘motorcycle maintenance course’ and if your lucky the local college will run one. A college nearish to me does an evening class for a term for not many pennies (considering the time they give you) and it covers the basics including using a multimeter to check bust indicators. It got me over my initial reluctance to touch anything mechanical. Quote Link to comment Share on other sites More sharing options...
JRH Posted June 17, 2018 Share Posted June 17, 2018 Halfords at 10 for a 2 pack of indicator bulbs and maybe even a cheap multimeter. No idea how to use the latter but maybe this is the start of my tech education. Stand by! Plenty of "how to use multimeter" web sites. Use continuity or resistance to see if the "bulb"is ok. Should be zero.Then check for volts at the holder. Set voltage range to cover 12 volts. Don't forget it is DC.Make sure the leads are in the correct ports and the selector switch is correctly set. If in doubt ask.HTH Quote Link to comment Share on other sites More sharing options...
Bender Posted June 17, 2018 Share Posted June 17, 2018 Set to volts see if you have any at bulb end, usually have a continuity setting with an audible setting so you can check cable, use resistance setting to check for poor connection, Google using multimeter they ain't complicated. Quote Link to comment Share on other sites More sharing options...
Beans Posted June 17, 2018 Author Share Posted June 17, 2018 Checked the bulb, its fine. Swapped it just to be doubly sure. No corrosion and bulb is connecting to contacts. Main battery and fuse are fine. There's no voltage at the contacts in the bulb holder. I guess it's something somewhere between between bulb holder and battery.. Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted June 17, 2018 Share Posted June 17, 2018 have you checked the relay as already mentioned above? Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 17, 2018 Share Posted June 17, 2018 Probably just one of the bullet connectors that link the indicator to the rest of the loom . Quote Link to comment Share on other sites More sharing options...
Beans Posted June 17, 2018 Author Share Posted June 17, 2018 I haveave a multimeter. All connections into the bulb holder are in, nothing loose.On the lead coming away from the bulb socket, about 8 inches or so away from the bulb, this connects to the bikes wiring loom with a male & female push socket, this too is clicked homeOff to the shop with it. Quote Link to comment Share on other sites More sharing options...
TimR Posted June 17, 2018 Share Posted June 17, 2018 using multimeter probes ( if they have pointy ends) pierce the wiring at points to see if power reaching places etc .Or try powering the bulb holder connecting socket from a 12v source ie bits of wire from battery +ve and -ve so you can rule that out ...then work your way back to next connection etc etc general set up is battery powers relay that then outputs to the switch which then selects which indicator to send the power to so from bulb holder work back to switch add power ... etc etc Quote Link to comment Share on other sites More sharing options...
Beans Posted June 17, 2018 Author Share Posted June 17, 2018 I can't get both of the multimeter probes down the loom side connector. Its extremely long and thin. Quote Link to comment Share on other sites More sharing options...
Beans Posted June 21, 2018 Author Share Posted June 21, 2018 For closure (shudder) took it to someone who knows what they are doing. They reckon it was moisture in the connections under the clocks They have sprayed with contact cleaner and the indicator started working After that they couldn't get it to break again. Quote Link to comment Share on other sites More sharing options...
