Liveware Problem Posted June 17, 2018 Share Posted June 17, 2018 Me again I've found that when accelerating hard in gears 4-6 there seems be a strange 'flat spot' around 6 - 7k rpm, the engine note changes and though the speed continues to rise the revs seem to pause around this spot, almost like hitting a limiter, and even fall back slightly (e.g. 7k down to 6.5k) whilst I'm still hard on the throttle, then continue on upwards.Is anyone able to shed any light on this, maybe [mention]Tango[/mention] or [mention]NeilM[/mention] ?I'm not 100% there's actually a problem, maybe I'm just not used to a triple? Quote Link to comment Share on other sites More sharing options...
TimR Posted June 17, 2018 Share Posted June 17, 2018 is it on stock exhaust ? Quote Link to comment Share on other sites More sharing options...
NeilM Posted June 17, 2018 Share Posted June 17, 2018 Me again I've found that when accelerating hard in gears 4-6 there seems be a strange 'flat spot' around 6 - 7k rpm, the engine note changes and though the speed continues to rise the revs seem to pause around this spot, almost like hitting a limiter, and even fall back slightly (e.g. 7k down to 6.5k) whilst I'm still hard on the throttle, then continue on upwards.Is anyone able to shed any light on this, maybe @Tango or @NeilM ?I'm not 100% there's actually a problem, maybe I'm just not used to a triple? I think mine does slightly lump out.Although to be honest it's only noticeable if you are looking for it.I found the triple took a while to get used to. If it is a similar issue I don't think you have anything to worry about Quote Link to comment Share on other sites More sharing options...
Westbeef Posted June 17, 2018 Share Posted June 17, 2018 Stock headers/exhaust system?Different bike, but mine does exactly this after changing them. Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted June 18, 2018 Author Share Posted June 18, 2018 Thanks for the replies Yes it is the stock exhaust, I can't be certain about the headers but I guess they are probably stock if the exhaust is?Today I was travelling quite quickly in 6th gear, rolled on the throttle some more and the revs 'jumped' from 7 - 9k almost instantaneously.. that can't be right, can it!? Quote Link to comment Share on other sites More sharing options...
megawatt Posted June 18, 2018 Share Posted June 18, 2018 If the revs increase and your speed doesn't, then your clutch is slipping. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted June 18, 2018 Share Posted June 18, 2018 sounds more like a clutch issue. My fuelling issue the bike bogs at 6k rpm and picks back up again, no extra revs or anything.Stick it in top gear at about 30-35mph and open the throttle, if it's the clutch it'll rev a lot more than it should as the clutch slips. Quote Link to comment Share on other sites More sharing options...
TimR Posted June 18, 2018 Share Posted June 18, 2018 If the revs increase and your speed doesn't, then your clutch is slipping.but reading previous post "the engine note changes and though the speed continues to rise the revs seem to pause around this spot,"would suggest its not clutch slip as speed increases but then reading the secondary post would give impression of clutch slip Have you just bought bike and wonder if previous had aftermarket exhsust on and removed and not remapped to standard exhaust Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted June 18, 2018 Share Posted June 18, 2018 Looks like a mapping issue to me.Before 'electronics', it would be carb tune / timing issue. Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 18, 2018 Share Posted June 18, 2018 If the revs increase and your speed doesn't, then your clutch is slipping. Yep , unfortunately it is at high speed and high gears that clutch slip often first presents itself . Not pulling away hard in low gears as you might expect. Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted June 18, 2018 Author Share Posted June 18, 2018 If the revs increase and your speed doesn't, then your clutch is slipping.but reading previous post "the engine note changes and though the speed continues to rise the revs seem to pause around this spot,"would suggest its not clutch slip as speed increases but then reading the secondary post would give impression of clutch slip Have you just bought bike and wonder if previous had aftermarket exhsust on and removed and not remapped to standard exhaust Yes sorry I have been slightly contradictory. But from what yourself and others have said, with the revs 'jumping' from higher in the band as I'm accelerating and going up through the gears, clutch slipping sounds highly likely I guess I should have learned after my first two bikes that a 'cheap deal' from a private seller is likely to be a false economy Quote Link to comment Share on other sites More sharing options...
Tango Posted June 19, 2018 Share Posted June 19, 2018 Clutch slip or drag can be a problem on these bikes.......but replacing the clutch plates is a doddle...... Quote Link to comment Share on other sites More sharing options...
megawatt Posted June 19, 2018 Share Posted June 19, 2018 If you need help with it, you're not that far from me. Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted June 20, 2018 Author Share Posted June 20, 2018 Clutch slip or drag can be a problem on these bikes.......but replacing the clutch plates is a doddle...... I think what you think of as a doddle may be slightly different to my idea of a doddle, changing clutch plates sounds more like 'nightmarish oily disaster with lots of cursing' [mention]megawatt[/mention] Thanks, very kind offer, I have arranged for the local shop to fit a new clutch and headstock bearings.. supposed to be going on a ride out on Sunday so I hope that can do it this Saturday. Quote Link to comment Share on other sites More sharing options...
megawatt Posted June 20, 2018 Share Posted June 20, 2018 Some people love giving money away. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 20, 2018 Share Posted June 20, 2018 Some people love giving money away. Nothing to worry about its not your money Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted June 20, 2018 Author Share Posted June 20, 2018 Some people love giving money away. Just doing my bit, supporting local businesses I really don't have the time to learn how to do it, and If I ever want to ride my bike rather than have it lying around in pieces for most of the year then a garage is the only option. Albeit an expensive one!That being said my buying history is pretty awful so have made a rod for my own back there. Quote Link to comment Share on other sites More sharing options...
