Zyxol Posted July 9, 2018 Share Posted July 9, 2018 Hi there.I have a year 2000 cb500. Just recently i have noticed a quiet, random ticking noise coming from the engine. Its not a knocking and doesnt seem to be affecting performance. It is not there when in neutral or with the clutch in. It sort of sounds like there is a small stone inside getting kicked about. I can hear it in 1st and 2nd but after 2 and a half thousand revs i suspect the engine noise covers it over. I have checked oil level, i have cleaned and checked the chain. Both are fineI did recently drop the bike, not sure if that's coincidence. I also stupidly pulled away with a chain still on by back wheel, no lock, just the chain so that pulled around, only one turn of the back wheel. That's the only two stupid things I've done. Other than that i use the bike to commute around London. Any thoughts on what could be the problem would be of great help. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 9, 2018 Share Posted July 9, 2018 Could be the clutch. Have a look at the cable at both ends, the actuator arm, then strip the clutch. Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted July 9, 2018 Share Posted July 9, 2018 hello & welcome Quote Link to comment Share on other sites More sharing options...
Zyxol Posted July 10, 2018 Author Share Posted July 10, 2018 Could be the clutch. Have a look at the cable at both ends, the actuator arm, then strip the clutch. Cheers for the suggestion. What would i be looking for on the cable ends? Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 10, 2018 Share Posted July 10, 2018 A small exhaust leak at the head can make a ticking noise . Quote Link to comment Share on other sites More sharing options...
Zyxol Posted July 10, 2018 Author Share Posted July 10, 2018 ***UPDATE***This morning the sound was almost gone, it came back as the engine heated up. Its been 1000miles since last oil change but the guy i bought it off used some shitty generic oil. Could the oil be knackered? Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 10, 2018 Share Posted July 10, 2018 Make sure you have clearance of at least 1/8" at the handlebar lever to the perch. Check adjusters are properly tightened up. Check that actuator works smoothly. If noise goes when clutch lever pulled in, problem is probably clutch internals. Quote Link to comment Share on other sites More sharing options...
Zyxol Posted July 10, 2018 Author Share Posted July 10, 2018 Make sure you have clearance of at least 1/8" at the handlebar lever to the perch. Check adjusters are properly tightened up. Check that actuator works smoothly. If noise goes when clutch lever pulled in, problem is probably clutch internals. Thanks for the advice. I'll check it out tonight. Clutch internals sounds expensive Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted July 10, 2018 Share Posted July 10, 2018 Not necessarily expensive - depends what the problem is.Once stripped, check, clean and if all OK, re-assemble. Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 10, 2018 Share Posted July 10, 2018 Not necessarily expensive - depends what the problem is.Once stripped, check, clean and if all OK, re-assemble. AND...if you stick a bit of wood under the back wheel and put the bike on the side stand you can usually strip a clutch without draining the oil . Quote Link to comment Share on other sites More sharing options...
Zyxol Posted July 10, 2018 Author Share Posted July 10, 2018 Amazing, thanks guys. Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 10, 2018 Share Posted July 10, 2018 Amazing, thanks guys. If the whole clutch is trashed ....https://m.ebay.co.uk/itm/HONDA-CB-500-F-2013-2015-CLUTCH/273218412127?hash=item3f9d161e5f:g:N-MAAOSwvDpa~Uqy Quote Link to comment Share on other sites More sharing options...
