Slowlycatchymonkey Posted July 10, 2018 Share Posted July 10, 2018 Some advice please. I’ve never cleaned or lubed my bike chain. How often should this be done and is it the same as a bicycle- puts some cleaner on, give it a scrub, rinse it off and spray some lube on? Quote Link to comment Share on other sites More sharing options...
Arwen Posted July 10, 2018 Share Posted July 10, 2018 Every bike is different, but generally you should be at least giving the chain a quick once over every ride - checking tension and condition. If it needs adjusted, then cleaning it at the same time makes sense to me. Depending on the weather conditions will depend on how often it needs cleaned. Dry and dusty conditions and/or wet conditions and it will need cleaned more often. The "top"/ middle of the chain is where it should be lubed. If it's dry there... then it's wearing the chain and sprockets more than it's meant too. And yes, clean like a push bike chain. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Every bike is different, but generally you should be at least giving the chain a quick once over every ride - checking tension and condition. If it needs adjusted, then cleaning it at the same time makes sense to me. Depending on the weather conditions will depend on how often it needs cleaned. Dry and dusty conditions and/or wet conditions and it will need cleaned more often. The "top"/ middle of the chain is where it should be lubed. If it's dry there... then it's wearing the chain and sprockets more than it's meant too. And yes, clean like a push bike chain. Oh I’ve not even looked at it once a week- oops. When I have looked at it the tensions been fine and I’ve not had to make any adjustments. Going to have to amend what I’m doing Quote Link to comment Share on other sites More sharing options...
Arwen Posted July 10, 2018 Share Posted July 10, 2018 You eventually get a feel for what is "normal" for your bike. With the MSX I do check the tension every ride, as it can stay in spec for weeks, then all of a sudden get way to slack (crap adjusters on it) My BMW however it is much more gradual, so I'll give it a nudge with my toe once a week or so. I it actually needs cleaned just now, because of all the dust in the air here. However it doesn't need adjusted to I am loathed to clean it, will seem like half a job! Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks for that. I’m hoping when I check it tomoz I don’t have an “oh dear” moment! How often do you check your tyre pressure? Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted July 10, 2018 Share Posted July 10, 2018 Triumph recommend chain lube every 200 miles, more often if riding in difficult conditions. I use the trip 2 to remind me and reset it after every lube/check. Tyres should be checked before every ride. You never know when you are going to pick up a nail. Quote Link to comment Share on other sites More sharing options...
JRH Posted July 10, 2018 Share Posted July 10, 2018 You could always fit an automatic chain oiler. Several on the market. Quote Link to comment Share on other sites More sharing options...
Arwen Posted July 10, 2018 Share Posted July 10, 2018 Thanks for that. I’m hoping when I check it tomoz I don’t have an “oh dear” moment! How often do you check your tyre pressure? Me? Probably not enough! Generaly after it has been sitting still for a while, or it starts to feel "odd" around corners. Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 10, 2018 Share Posted July 10, 2018 DO NOT CLEAN LIKE A PUSHBIKE CHAIN IF IT HAS O RINGS. Clean it with a soft brush using paraffin every month. Clean paraffin off with brake cleaner on a Terry towel until its bone dry. Lube with a dry ptfe lube, like Wurth, every 200 miles. Check tension every time you ride it. Lube it after a long ride, while it's hot. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks all. Am going to have a look at the automatic dispensers. Shall be amending my sparse schedule accordingly! Don’t know what an o ring is though? Quote Link to comment Share on other sites More sharing options...
Gerontious Posted July 10, 2018 Share Posted July 10, 2018 Thanks all. Am going to have a look at the automatic dispensers. Shall be amending my sparse schedule accordingly! Don’t know what an o ring is though? its effectively a seal.. that keeps grease inside the chain where a lot of wear would normally take place. They also keep grit and other contaminants out.. both attributes extend the life of the chain. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks all. Am going to have a look at the automatic dispensers. Shall be amending my sparse schedule accordingly! Don’t know what an o ring is though? its effectively a seal.. that keeps grease inside the chain where a lot of wear would normally take place. They also keep grit and other contaminants out.. both attributes extend the life of the chain. Oh ok thanks, sounds like an expensive chain and not the sort you’d find on a Chinese 125! Quote Link to comment Share on other sites More sharing options...
Gerontious Posted July 10, 2018 Share Posted July 10, 2018 Thanks all. Am going to have a look at the automatic dispensers. Shall be amending my sparse schedule accordingly! Don’t know what an o ring is though? its effectively a seal.. that keeps grease inside the chain where a lot of wear would normally take place. They also keep grit and other contaminants out.. both attributes extend the life of the chain. Oh ok thanks, sounds like an expensive chain and not the sort you’d find on a Chinese 125! They're fairly standard now.. been around since the early 1970s. In the early days they were expensive and restricted to certain machinery.. now they're practically standard on motorcycles of all kinds. even the cheapest. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 its effectively a seal.. that keeps grease inside the chain where a lot of wear would normally take place. They also keep grit and other contaminants out.. both attributes extend the life of the chain. Oh ok thanks, sounds like an expensive chain and not the sort you’d find on a Chinese 125! They're fairly standard now.. been around since the early 1970s. In the early days they were expensive and restricted to certain machinery.. now they're practically standard on motorcycles of all kinds. even the cheapest. Oh how can I tell what I have? Quote Link to comment Share on other sites More sharing options...
Mickly Posted July 10, 2018 Share Posted July 10, 2018 Take you keks offPut a mirror behind you and bend overLook over your shoulder -if you say ‘oh! ring ‘ there you have itOr not !!! Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Take you keks offPut a mirror behind you and bend overLook over your shoulder -if you say ‘oh! ring ‘ there you have itOr not !!! Quote Link to comment Share on other sites More sharing options...
geofferz Posted July 10, 2018 Share Posted July 10, 2018 I use wd40 and this chain cleaning brush https://m.ebay.co.uk/itm/MTB-Bike-Bicycle-Motorcycle-Chain-Wheel-Cleaning-Brush-Wash-Cleaner-Tool-Kit-New/392064546294?epid=15020394108&hash=item5b48de35f6:g:pZcAAOSwWfdbIjQKThen lube it. Paddock stand or center stand really helps. Quote Link to comment Share on other sites More sharing options...
Gerontious Posted July 10, 2018 Share Posted July 10, 2018 Oh ok thanks, sounds like an expensive chain and not the sort you’d find on a Chinese 125! They're fairly standard now.. been around since the early 1970s. In the early days they were expensive and restricted to certain machinery.. now they're practically standard on motorcycles of all kinds. even the cheapest. Oh how can I tell what I have? send them an email and ask. [email protected] Quote Link to comment Share on other sites More sharing options...
geofferz Posted July 10, 2018 Share Posted July 10, 2018 Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 They're fairly standard now.. been around since the early 1970s. In the early days they were expensive and restricted to certain machinery.. now they're practically standard on motorcycles of all kinds. even the cheapest. Oh how can I tell what I have? send them an email and ask. [email protected] Thanks might leave it a minute before bugging them as I’ve emailed them twice today asking what oil to use, if it’s a wet clutch and could they post me out a new brake lever owing to an oops in the car park rendering the other one a bit curvier than usual. Only £14 for a new brake lever though which sounds pretty good value. Quote Link to comment Share on other sites More sharing options...
bonio Posted July 10, 2018 Share Posted July 10, 2018 I use wd40 and this chain cleaning brush https://m.ebay.co.uk/itm/MTB-Bike-Bicycle-Motorcycle-Chain-Wheel-Cleaning-Brush-Wash-Cleaner-Tool-Kit-New/392064546294?epid=15020394108&hash=item5b48de35f6:g:pZcAAOSwWfdbIjQKThen lube it. Paddock stand or center stand really helps.Have we done this topic before? Or is it just déja vue? (classy 'é' )I thought WD40 was a no-no for chains, an O ring killer. Or have I just been believing old wives' tales? Quote Link to comment Share on other sites More sharing options...
bonio Posted July 10, 2018 Share Posted July 10, 2018 As a rule of thumb, I was told to lube every 300 miles, clean and lube every 900/1000 miles. But it depends on the kind of conditions you're riding in; I wouldn't clean the chain as often asthis if the bike doesn't see any rain. Quote Link to comment Share on other sites More sharing options...
Six30 Posted July 10, 2018 Share Posted July 10, 2018 Every 300 miles . Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted July 10, 2018 Author Share Posted July 10, 2018 Every 300 miles . So your saying well over 2000 miles might be pushing it? Quote Link to comment Share on other sites More sharing options...
Six30 Posted July 10, 2018 Share Posted July 10, 2018 Every 300 miles . So your saying well over 2000 miles might be pushing it? Slightly Quote Link to comment Share on other sites More sharing options...
