ART-ADS Posted July 17, 2018 Share Posted July 17, 2018 the cable on the vt is a push pull mechanism, I didn't realise that the return cable 'push' side was rusted until I changed the bars because it seemed to be working fine. the regular pull cable that you find on single cable throttles in In tact and I assume the spring in the carb is good because it snaps back shut afterwards. my question is would it be ok to solder the pull cable back together as it split pretty clean because the part right now is out of stock so I don't know how long that might take for it to be available. thoughts? is it necessary as the throttle is workin fine it seems but I wouldn't want the broken cable to snag and hold the throttle open down the road idk thoughts?? Quote Link to comment Share on other sites More sharing options...
Guest Posted July 17, 2018 Share Posted July 17, 2018 There is no "push" side - the double cable ensures that the carb is positively controlled both when opening and closing, thus allowing the use of a much lighter spring on the carb slide and giving a much lighter throttle action. As far as soldering the old cable back together goes, forget it. Can you obtain a length of wire cable of the appropriate dimensions and some new nipples? If so, you could make a new inner. Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 17, 2018 Share Posted July 17, 2018 You don't necessarily need the closing cable, as long as the spring shuts the throttle quickly WHILE THE ENGINE IS RUNNING AT FULL SPEED. I've binned closing cables on loads of bikes, but mainly four cylinders with extra springs on the throttle bar that operates all four throttles. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted July 28, 2018 Share Posted July 28, 2018 If the spring is external to the carb(s), you can replace with a stronger spring and 'bin' the return cable. Quote Link to comment Share on other sites More sharing options...
TimR Posted July 28, 2018 Share Posted July 28, 2018 either do away and add an extra return spring BUT new mot rules may raise issues if the sloppy grip return or https://www.halfords.com/motoring/motorcycling/motorcycle-accessories/oxford-motorcycle-cycle-cable-repair-kit-2017 Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 28, 2018 Share Posted July 28, 2018 You don't necessarily need the closing cable, as long as the spring shuts the throttle quickly WHILE THE ENGINE IS RUNNING AT FULL SPEED. I've binned closing cables on loads of bikes, but mainly four cylinders with extra springs on the throttle bar that operates all four throttles. Couldn't have put it better , I too have often junked closing cables . As long as the throttle snaps shut you're ok . Quote Link to comment Share on other sites More sharing options...
