jack27808 Posted July 29, 2018 Share Posted July 29, 2018 Hi all, I recently bought a Suzuki GS500 (02 reg) and I've been having problems with the battery. Initially I thought the battery was at fault however I've replaced this and still have issues.If the bike is not used for a few days the battery has little charge left and when i go out for 20 miles rides it doesn't appear to be charging at all. Actually, the bike frequently cuts out towards the end of these rdies and then I can't get it started again due to dead battery.I've followed the steps to check the R/R from the John Bates charging circuit test (and a bunch of other guides). Measurements are:1. (battery) All off = 12.88 / 13.12. Idle (1200RPM) = 13.9. 2500 rev = 14.2. 5000 rev = 14.15 (However, this doesn't always happen, sometimes there is no increase)2. 14.24. 60mv6. 48mv8. y1-y2 = 1.5 ohms. Y1-y3 = 1.5 ohms. Y2-y3 = 1.4 ohms10. OL for all12. y1-y2 = 65v. y1-y3=66v. y2-y3 = 65V14. Red – y1 = 498mv. Red-y2 = 510mv. Red-y3 = 513mv16. OL for all18. y1 =514mv. Y2 = 512mv. Y3 = 510mv Stator current (AC) at 5000 RPM between leads:65v, 66v and 65v The connection with the Red and b/w connects to the cable coming from the R/R and looks damaged/corroded. The yellow wires that also connect up to those coming from the R/R get fairly hot to the touch. Could the R/R be OK and this connection be the issue? I'm not mechanically sound particularly but I don't really want to pay a fortune for a mechanic to test things, any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Tango Posted July 29, 2018 Share Posted July 29, 2018 Welcome to TMBF mate. ........ Yes.....sounds like you may have a dodgy connection there......The connector shouldn't get hot...... Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 29, 2018 Share Posted July 29, 2018 Welcome, can't see your images , its really easy to upload direct to the forum , just go attachments, add files , select from your images , wait for the tick and submit . Quote Link to comment Share on other sites More sharing options...
jack27808 Posted July 29, 2018 Author Share Posted July 29, 2018 Images attached - sorry!The images aren't the connection that gets hot, that's the three yellow wires that connect from the stator to the R/R. The imags are the other wire that connects to the R and B/w wires coming from the R/R. Following a bunch of guides, the readings I get from the R/R diode checks would suggest that this is the fault. However, the readings I get are all consistent:14. Red – y1 = 498mv. Red-y2 = 510mv. Red-y3 = 513mv (positive swing diode, reverse bias check)16. OL for all (positive swing diode, Froward bias check)18. y1 =514mv. Y2 = 512mv. Y3 = 510mv (negative swing diode, reverse bias check)20. OL for all (negative swing diode, forward bias check)The guides say that I should be getting readings of OL or over 1.5V for 14 and 18 and readings of around 0.5V for 16 and 20. I've learnt alot about the charging system this weekend but I'm not sure what's going on and don't have a working R/R to test. Quote Link to comment Share on other sites More sharing options...
HomerPlata Posted July 31, 2018 Share Posted July 31, 2018 Sorry I can't offer any solution, but I did used to have a GS500F which had similar electrical issues (especially in the wet), so I can sympathise. It's a shame, because I loved that bike otherwise, I just couldn't trust it to start in the cold/wet without getting some expensive work done to it Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 31, 2018 Share Posted July 31, 2018 Just a thought, if all this heat is being generated either side of something that is designed to generate and dissipate heat then I can only assume that the reg rec is at fault . Try upgrading to a Honda CB 250 n pattern one . Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 2, 2018 Share Posted August 2, 2018 As above AND - Replace that connector! Quote Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2018 Share Posted August 2, 2018 And herein lies the clue...."1. (battery) All off = 12.88 / 13.12. Idle (1200RPM) = 13.9. 2500 rev = 14.2. 5000 rev = 14.15 (However, this doesn't always happen, sometimes there is no increase"The connector in your photo looks well dodgy.......I would suspect a bad/intermittent contact. The presence of heating would tend to reinforce this conclusion.Try cleaning all of the R/R connectors then pack with dielectric grease. The R/R itself is probably OK as usually they either work or not. Let us know how you get on.CheersS23 Quote Link to comment Share on other sites More sharing options...
Guest Posted August 19, 2018 Share Posted August 19, 2018 Additional,Heat in wires and connectors come from two sources, either sparking due to loss of connection, in which case something needs cleaning or replacing, or due to being too small to carry the current. For example wires that are too thin often become hot in use.Heat suggests something is very wrong either clean or swap the connector or piggyback a second wire bypassing the hot section increasing the current flow.This heating of wiring due to age, low capacity, and insufficient size to carry the current is the cause of most electrical fires.It needs sorting out. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 19, 2018 Share Posted August 19, 2018 Dodgy connection due to corrosion more than enough to cause problems described. Needs a good cleaning out. Quote Link to comment Share on other sites More sharing options...
