Matt0503 Posted September 3, 2018 Share Posted September 3, 2018 Hi, guys i managed to buy a lexmoto hunter yesterday. I rode it back home for 15 miles and when i got home i noticed an oil leak, it was coming from the stator casing. I took it off and there was oil there (not much) , im not sure if there is supposed to be oil as there is a screw from the top (as if to fill up) however there is also a hole on the bottom for liquids to escape (factory). Please help, also i wanted to change the oil in the engine and unscrewed one bolt from underneath the engine... a spring came out with the bolt and a few ml of oil (not much at all) after screwing this back in i noticed that there is a second bolt.... so my question is why are there 2 bolts? I thought that maybe the one i unscrewed was for a filter, but there was no filter. Plus why would only a bit of oil pour out. Thanks for any messages in advance, i will try to read them asap Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted September 3, 2018 Share Posted September 3, 2018 Sounds like you've taken the gear selector detent bolt out - that's often the one with a spring and usually a domed unit (though that may not have dropped out). If there are two bolts I'd guess the other is the oil drain.Can you find a manual for this engine? Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted September 3, 2018 Share Posted September 3, 2018 Have a look on Chinese motorcycle parts online. You can search on thee for a parts diagram on there I have had a quick look and your bike is listed.Dave Quote Link to comment Share on other sites More sharing options...
Matt0503 Posted September 16, 2018 Author Share Posted September 16, 2018 Thanks for the replies, I will try to look for a manual, i have managed to find the parts i needed, but how on earth do i take the flywheel off? It doesnt move even with a gear puller on it. . 2 days ago i noticed my starter not starting the engine... turns out its the starter motor clutch behind the FLYWHEEL. Which is not going anywhere anytime soon, so now i have a stuck flywheel with an oil leak and a faulty starter clutch behind it. I was thinking to cut the flywheel off and just order a new one. Please help.(Lexmoto ) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 16, 2018 Share Posted September 16, 2018 DO NOT CUT THE FLYWHEEL OFF ELSE YOU WILL F*UCK YOUR ENGINE. Was that loud enough? You need the proper extractor to get it off. It costs about £6.50. And get a manual while you're at it. Remember - Google is your friend!Edited to add: There was a remarkably similar post on here not long ago. Coincidence? I think we should be told. Quote Link to comment Share on other sites More sharing options...
Matt0503 Posted September 19, 2018 Author Share Posted September 19, 2018 Loud enough, thanks , can you help me out in figuring out why a proper extractor is going to Be better than the one i bought? Also i need to restrict the bike to 30mph, i tried to buy a new standard cdi because the previous owner put a racing one on, but no help, does it need to be titled as a restricted cdi? Any other ways j can restrict it? Its hard because its a geared bike so cant restrict it in the throttle, will a restricted exhaust work? Quote Link to comment Share on other sites More sharing options...
