Mrbubba Posted September 13, 2018 Share Posted September 13, 2018 I've seen some crash bungs on eBay, they are listed for a Kawasaki Er6F, it's the same year bike as mine, but mine is a Er6n (naked version). I've tried Google but can't see if they would fit and the seller is not sure, but thinks the frame is the same once the faring is off the bike.Any ideas? Quote Link to comment Share on other sites More sharing options...
megawatt Posted September 13, 2018 Share Posted September 13, 2018 If they fit a faired bike, I'd be surprised if they didn't fit a naked. Make sure they use 10 mm bolts and not 8mm. Quote Link to comment Share on other sites More sharing options...
Tango Posted September 13, 2018 Share Posted September 13, 2018 Don't see any reason why they wouldn't fit your bike......as Megawatt says, they normally bolt to the engine mounts, which will be the same for your bike and the faired version...... Quote Link to comment Share on other sites More sharing options...
Mrbubba Posted September 13, 2018 Author Share Posted September 13, 2018 Received a reply from the seller about the bolts The bolt through the middle of the bung is 10mm. The others are 8mm. Hope this helps They are genuine Kawasaki bungs and £25 plus postage, so could be worth a go Quote Link to comment Share on other sites More sharing options...
megawatt Posted September 13, 2018 Share Posted September 13, 2018 Anything better than nothing. Could save major, expensive damage. Quote Link to comment Share on other sites More sharing options...
