Tankbag Posted September 15, 2018 Share Posted September 15, 2018 From a busa fb post, any suggestions welcome thanks " Hayabusa Gen1 RY.Running REALLY RICH.Has had, Fuel pump n all filters changed.New OEM fuel pipes.Pressure regulator.Plugs n caps/ coils.Throttle position Sensor.( set to centre line on readout).K&N panel filter.Standard pipes n scorpion carbon cans.Standard apart from this on engine. 63k miles. Running very rough at idle.Black smoke from exhaust on start up. Hesitates on pick up if given loads n engine wants to die on upshifts.Any ideas appreciated. Rust in tank???? Ive read this could be culprit??? " Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted September 15, 2018 Share Posted September 15, 2018 Sounds like it needs an italian tuneup Quote Link to comment Share on other sites More sharing options...
Stu Posted September 15, 2018 Share Posted September 15, 2018 check for fuel in the oil or rising oil levels could be a sticking injector The TL s&r suffered with this and could possibly be the same injectors Quote Link to comment Share on other sites More sharing options...
Stu Posted September 15, 2018 Share Posted September 15, 2018 Also check to make sure coolant temp sensor is working correctly and the bike is getting to operating temp as these systems have a cold running map that uses more fuel Quote Link to comment Share on other sites More sharing options...
Bender Posted September 15, 2018 Share Posted September 15, 2018 I would be looking at injectors too, it's running rich it's either thinking it's got more air than it needs or it's putting too much fuel in for the air that it's got, make sure any thing else sensor wise is reading what it's supposed to be. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted September 15, 2018 Author Share Posted September 15, 2018 Thanks Chaps I've posted that over hope it helps, I'll post back assuming the guy finds the problem Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted September 16, 2018 Share Posted September 16, 2018 Is it flooding all the cylinders or just one? Quick plug check would tell.Throttle bodies balanced and set correctly relative to tps?Electrical system ok,not over or under charging?ECU? Bad earths?Valve clearances?Bit of a long shot; cam timing ok,not got a worn chain or anything?Did it start running rough just one day out the blue or was it a gradual event? Quote Link to comment Share on other sites More sharing options...
Tankbag Posted September 16, 2018 Author Share Posted September 16, 2018 Is it flooding all the cylinders or just one? Quick plug check would tell.Throttle bodies balanced and set correctly relative to tps?Electrical system ok,not over or under charging?ECU? Bad earths?Valve clearances?Bit of a long shot; cam timing ok,not got a worn chain or anything?Did it start running rough just one day out the blue or was it a gradual event?I don't know, sounds like a demon in his bike, I'll post your post over. Quote Link to comment Share on other sites More sharing options...
Stu Posted September 16, 2018 Share Posted September 16, 2018 You could always send him a link to the thread Quote Link to comment Share on other sites More sharing options...
Tankbag Posted September 16, 2018 Author Share Posted September 16, 2018 You could always send him a link to the thread Captain Manwaring " I wondered when you'd spot that " Quote Link to comment Share on other sites More sharing options...
Justarn Posted September 16, 2018 Share Posted September 16, 2018 Lamda sensor probably, can you read the codes? If so get a code reader. Quote Link to comment Share on other sites More sharing options...
