SuchANewb Posted September 16, 2018 Share Posted September 16, 2018 Ok, so my drive chain was really slack so I followed the manual instructions, loosened the brake pedal free play nut, the brake torque rod nut and the axle nut and then tightened the chain. As far as I can tell the rear wheel is aligned with the marks in the window being even. Then, as per the manual I tightened everything back up to within the manual specs.But now, the arm that links the brake pedal to the brake lever doesn’t return properly - it sticks and the rear wheel is sticking to the point it won’t move at all. I’ve tried a bit of WD-40 on the springs but that hasn’t helped.Any suggestions would be really appreciated.Thanks Quote Link to comment Share on other sites More sharing options...
Tango Posted September 16, 2018 Share Posted September 16, 2018 Welcome to TMBF mate. ......pop over to the Newbies section and introduce yourself to the guys when you can. .... As to your problem. .......If the chain was really knackered (and likely the sprockets too), then the distance you've moved the rear wheel back may be further than the brake rod and torsion bar can cope with......New chain (and sprockets) may sort your problem. ..... Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted September 16, 2018 Share Posted September 16, 2018 Just to be clear, undoing the brake pedal free play nut (the weird shaped one) doesn't help? Quote Link to comment Share on other sites More sharing options...
TimR Posted September 16, 2018 Share Posted September 16, 2018 have you overtightened the torque arm bolt ..? try slackening this off and apply brake ( test it stationary ) Quote Link to comment Share on other sites More sharing options...
SuchANewb Posted September 18, 2018 Author Share Posted September 18, 2018 Thanks for the replies.Last night I did everything again - I redid the drive chain slack and wheel alignment and now it seems to be working. I think I might have started moving the brake pedal free play nut before I tightened the brake torque rod nut - not sure if this would have made a difference.Anyway, now the brake pedal free play is within the manual specs and the wheel moves freely.Now time to clean it!!Thanks again Quote Link to comment Share on other sites More sharing options...
