fifthwheel Posted September 17, 2018 Share Posted September 17, 2018 Hi all, I have a Honda 125 Pantheon I am doing a few jobs for the MOT.The rear adjustable shocker is seized. It is dry and working fine but cannot be adjusted is this a MOT fail? thanks John. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2018 Share Posted September 17, 2018 Hi all, I have a Honda 125 Pantheon I am doing a few jobs for the MOT.The rear adjustable shocker is seized. It is dry and working fine but cannot be adjusted is this a MOT fail? thanks John.If it cannot be adjusted because of corrosion, it is a fail. "..... a rear suspension component which is: a. loose, cracked, excessively bent, misaligned or excessively corroded"Here, have a look - you might find it useful:http://www.motuk.com/bike/2-4.asp#Menu_TopHave fun. Quote Link to comment Share on other sites More sharing options...
fifthwheel Posted September 17, 2018 Author Share Posted September 17, 2018 Thanks for the link thats very useful. Its not corroded but stuck and has been painted over. Its not been moved for years, If I try to free it I think it will be scrap but might as well try if its a fail as it is. john. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2018 Share Posted September 17, 2018 If it's not obviously corroded, leave it.......if the shock is still working, then the tester would have no cause to try to adjust it. Quote Link to comment Share on other sites More sharing options...
fifthwheel Posted September 17, 2018 Author Share Posted September 17, 2018 If it's not obviously corroded, leave it.......if the shock is still working, then the tester would have no cause to try to adjust it.Ok will do, I thought perhaps if a passenger was to be carried the tester might say I couldn't adjust it and fail the bike.Will leave it and go for the test. Quote Link to comment Share on other sites More sharing options...
