Mickly Posted September 21, 2018 Share Posted September 21, 2018 I have 10 Dowty washers ( rubber with metal inserts ) that fit under the cam cover bolts on the Trophy.They were caked in a hard residue that I reckon was limescale, replacements are about £5 each.After a bit of research I created a mixture of white wine vinegar and lemon juice & left the washers to stew over night.This morning most of the lime scale had disappeared and what was left could be easily scraped out of the grooves with a cocktail stick.Rinsed and dried - job done Saved myself £50 Quote Link to comment Share on other sites More sharing options...
raesewell Posted September 21, 2018 Share Posted September 21, 2018 You must use gold plated Dowty washers Quote Link to comment Share on other sites More sharing options...
Mickly Posted September 21, 2018 Author Share Posted September 21, 2018 You must use gold plated Dowty washers They are Triumph OE parts - nuff said Quote Link to comment Share on other sites More sharing options...
Guest Posted September 21, 2018 Share Posted September 21, 2018 Outstanding Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 22, 2018 Share Posted September 22, 2018 Should have used Cillit Bang ( I am not Barry Scott ) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2018 Share Posted September 22, 2018 You must use gold plated Dowty washers They are Triumph OE parts - nuff saidI doubt whether Triumph actually make these.... If they can source them, so can you.... Quote Link to comment Share on other sites More sharing options...
