TitanBax Posted September 29, 2018 Share Posted September 29, 2018 I have been all over google and YouTube looking for assistance with no luck. I have found some videos that mention plugs and then they seem to be miraculously removed. I have done 2 and 3. But can’t physically see how to get 1 and 4 out. The Haynes manual is next to useless as ever. It looks like I have to take loads of extra bits of to be able to get the coil out. I have undone the water pump which helped with two. Any help would be my appreciated.Titan Quote Link to comment Share on other sites More sharing options...
Tango Posted September 30, 2018 Share Posted September 30, 2018 I have been all over google and YouTube looking for assistance with no luck. I have found some videos that mention plugs and then they seem to be miraculously removed. I have done 2 and 3. But can’t physically see how to get 1 and 4 out. The Haynes manual is next to useless as ever. It looks like I have to take loads of extra bits of to be able to get the coil out. I have undone the water pump which helped with two. Any help would be my appreciated.Titan Anything on YouTube? ......Other than that I can't help I'm afraid....... Quote Link to comment Share on other sites More sharing options...
Tango Posted September 30, 2018 Share Posted September 30, 2018 Found this......may help slightly........ https://youtu.be/O1pfUKJ03-8 Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 30, 2018 Share Posted September 30, 2018 (edited) This sort of thing is one reason I'm still looking at getting a Harley. Admittedly I don't have a water pump stuck on top of my engine on the GSXR but a job like a plug change is still a massive pain in the arse. EDIT : I thought so , all that gubbins on top of the engine isn't the actual water pump, that's down below and driven off the engine the same as on my bike . I do have a tip for getting the new plugs back in , I stick them into a length of rubber tube then dangle and twiddle until the threads engage . When they do , I pull the tube off and finish the job with the extended box spanner supplied by Suzuki. Edited September 30, 2018 by fastbob Quote Link to comment Share on other sites More sharing options...
JRH Posted September 30, 2018 Share Posted September 30, 2018 [mention]TitanBax[/mention] there should be 2 intentions in the side of the top frame. This should give enough room to wiggle the coils out from 1&4 plugs with the fairing removed.I have the workshop manual for he GSF1250 and it does not list any other way to get the plugs out. Quote Link to comment Share on other sites More sharing options...
TitanBax Posted October 1, 2018 Author Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2018 Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. Just don't bleep out the cussing and swearing......adversity is what we like to see Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 1, 2018 Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. The maker of that video must have edited out at least an hour of f*****g about ! One minute he's talking about it , the next, hey presto ! all four plugs are neatly laid out on his spotless carpet tiles. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 1, 2018 Share Posted October 1, 2018 Found this ..Thanks Joe, I figured it out, as I went back out and looked underneath the frame an found that there is a cutout in the frame for the coils to slide past. Courtesy of Texas Riders . I also found this ( hope I'm not in violation of any rules here ) Quote Link to comment Share on other sites More sharing options...
TitanBax Posted October 1, 2018 Author Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. The maker of that video must have edited out at least an hour of f*****g about ! One minute he's talking about it , the next, hey presto ! all four plugs are neatly laid out on his spotless carpet tiles. YES. And that is what is so frustrating. He must have managed to get them out, and it can’t have been that easy. I will try and post a video Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 1, 2018 Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. The maker of that video must have edited out at least an hour of f*****g about ! One minute he's talking about it , the next, hey presto ! all four plugs are neatly laid out on his spotless carpet tiles. YES. And that is what is so frustrating. He must have managed to get them out, and it can’t have been that easy. I will try and post a video Have you seen what else I've posted ? Quote Link to comment Share on other sites More sharing options...
kingmunky Posted October 1, 2018 Share Posted October 1, 2018 Same as the bandit engine - utter pain in the arse to remove the sparks although I found 2 & 3 were the problem not so much 1 & 4. Anyway, the best way I found was to twist and pull the plugs bit by bit and when you get them high enough to come into contact with the frame turn them about 150 degress so the lead connection is facing in toward the engine, tilt the plug that way and it *should* slide out. (EDIT: Removed 45 minutes of swearing, smoking and frustration for sake of a quick post) Quote Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2018 Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. The maker of that video must have edited out at least an hour of f*****g about ! One minute he's talking about it , the next, hey presto ! all four plugs are neatly laid out on his spotless carpet tiles.Slightly off topic but on the subject of making videos, there is a guy who has a channel "2 wheel obsession" that is about FJR 1300s. Some good stuff, BUT you could cut at least 30 minutes out of each video as he fecks about rummaging about for and fetching tools that could have been at his fingertips. On one video about removing the side covers we were treated to about a 10 minute discussion on the different side cover colour schemes that are available in the US, Canada, Europe, etc. etc. etc. - all the while just looking at the damn things, and NOT removing them. So sometimes brevity is best! Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 1, 2018 Share Posted October 1, 2018 Thanks for the pointers so far. I think I looked at that video before. The videos never show the actual removal of the ignition coils. I think I will make a video myself and post it up on YouTube. The maker of that video must have edited out at least an hour of f*****g about ! One minute he's talking about it , the next, hey presto ! all four plugs are neatly laid out on his spotless carpet tiles.Slightly off topic but on the subject of making videos, there is a guy who has a channel "2 wheel obsession" that is about FJR 1300s. Some good stuff, BUT you could cut at least 30 minutes out of each video as he fecks about rummaging about for and fetching tools that could have been at his fingertips. On one video about removing the side covers we were treated to about a 10 minute discussion on the different side cover colour schemes that are available in the US, Canada, Europe, etc. etc. etc. - all the while just looking at the damn things, and NOT removing them. So sometimes brevity is best!But the guy completely omitted the entire plug removal process including the particularly troublesome No.2 plug . Quote Link to comment Share on other sites More sharing options...
Tango Posted October 1, 2018 Share Posted October 1, 2018 Another guy posted up a video on youtube changing his plugs on his GSX650........He gave up..... Quote Link to comment Share on other sites More sharing options...
TitanBax Posted October 1, 2018 Author Share Posted October 1, 2018 I saw that one! How not to change the plugs. Quote Link to comment Share on other sites More sharing options...
TitanBax Posted October 1, 2018 Author Share Posted October 1, 2018 Thanks to Kingmunky who confirmed what I had perhaps been thinking. Basically there is a gap, and if you undo (not completely) the bolt that holds the top fairing on you have just enough space to get it through. I have also done my first ever YouTube video! "> Thanks everyone that helped! I haven’t had a chance to do number four this evening. Will try and do that tomorrow night if I get home a little earlier to make use of the diminishing light. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 1, 2018 Share Posted October 1, 2018 this picture seems very apt for what you're going through Quote Link to comment Share on other sites More sharing options...
