Mickly Posted November 14, 2018 Share Posted November 14, 2018 So ... I’m stripping the carbs of the Trophy to give them a good clean and maybe some jetting work to suit a freer flowing inlet and exhaust.Why do we complain that the fixings are made of cheese when they churn up and slip .... only to complain that they are hard as iron when we try and slot them with a junior hacksaw???Eventually used the Dremel to cut a slot and remove the bast*rd, only 6 more to go. Here is the recalcitrant bugger - the red stuff started dripping from my finger when the original screwdriver bit slipped !! Quote Link to comment Share on other sites More sharing options...
Tango Posted November 14, 2018 Share Posted November 14, 2018 Thank heavens for Dremels. .......and their bigger brother, the angle grinder! ........ Quote Link to comment Share on other sites More sharing options...
NeilM Posted November 14, 2018 Share Posted November 14, 2018 And the even bigger brother.Can't beat a gas axe..... Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 And the even bigger brother.Can't beat a gas axe..... H’mmmNot sure the carbs would take kindly to that Quote Link to comment Share on other sites More sharing options...
Stu Posted November 14, 2018 Share Posted November 14, 2018 They chew up because you are probably using the wrong screwdriver You will need a set of JIS screwdrivers Even though its a brit bike Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 JIS??I seem to recall something about that ...Is that because they are Japanese Mikuni carbs? Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 Is it the same as Posi drive? Quote Link to comment Share on other sites More sharing options...
Tango Posted November 14, 2018 Share Posted November 14, 2018 Is it the same as Posi drive? No......JIS are the Japanese version of Philips.......but they grip the screw head better...... Quote Link to comment Share on other sites More sharing options...
Stu Posted November 14, 2018 Share Posted November 14, 2018 JIS is Japanese Industrial Standard they are very similar but pozi drive will just cam out of the JIS screws where as JIS screwdrivers fit like a glove and they also fit pozi drive Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 OohhMaybe something to treat myself to at the bike show this weekend!! Quote Link to comment Share on other sites More sharing options...
Stu Posted November 14, 2018 Share Posted November 14, 2018 OohhMaybe something to treat myself to at the bike show this weekend!! I hope you find them! i have never seen them at the show although I have never looked either Quote Link to comment Share on other sites More sharing options...
Stu Posted November 14, 2018 Share Posted November 14, 2018 this is the set I have its come down in price a little too https://www.ebay.co.uk/itm/JIS-Screwdriver-Set-Motorcycle-9-Piece-Complete-Kit-VMCK9/171953736412?epid=1249877915&hash=item28093dcadc:g:wvkAAOSw37tWC92J:rk:48:pf:0 Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 FFS£82 for a few screw drivers??I’ll be looking for some bits that fit into a socket. Quote Link to comment Share on other sites More sharing options...
Stu Posted November 14, 2018 Share Posted November 14, 2018 Worth every penny to me you can get cheaper ones though so have a look about Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 14, 2018 Author Share Posted November 14, 2018 Depends upon the price you put on your blood!! Quote Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2018 Share Posted November 14, 2018 Reasonable cost JIS here:https://www.ebay.co.uk/itm/Laser-7036-4-Piece-JIS-Screwdriver-Set/142773399122?_trkparms=aid=333200&algo=COMP.MBE&ao=1&asc=20180409081753&meid=e0804c4186f64390842fbabb36c293ad&pid=100008&rk=1&rkt=12&sd=171753460588&itm=142773399122&_trksid=p2047675.c100008.m2219&redirect=mobileI bought a hex drive set but can't find the link...... Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted November 14, 2018 Share Posted November 14, 2018 Being a cheapskate I just took my dremel to a standard set of pozidrive screwdrivers which seems to have worked pretty well. Just taking the tip off is a good starting point. Quote Link to comment Share on other sites More sharing options...
fastbob Posted November 15, 2018 Share Posted November 15, 2018 And when you do get them all out nip up to Tool Station and get a bag of M5 x 16 stainless Allen bolts and dip them all in Copper Slip . You know it makes sense. https://www.toolstation.com/shop/Screws+%26+Fixings/d90/Stainless+Steel+Screws/sd810/Stainless+Steel+Socket+Cap+Screw/p29995 Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted November 15, 2018 Share Posted November 15, 2018 Reasonable cost JIS here:https://www.ebay.co.uk/itm/Laser-7036-4-Piece-JIS-Screwdriver-Set/142773399122?_trkparms=aid=333200&algo=COMP.MBE&ao=1&asc=20180409081753&meid=e0804c4186f64390842fbabb36c293ad&pid=100008&rk=1&rkt=12&sd=171753460588&itm=142773399122&_trksid=p2047675.c100008.m2219&redirect=mobileI bought a hex drive set but can't find the link...... Ordered a set Quote Link to comment Share on other sites More sharing options...
Mickly Posted November 16, 2018 Author Share Posted November 16, 2018 Got a set of Halfords Advanced Screwdrivers 1/2 price (£10)Spoke to the guy at the bike station who knew about JIS ( unlike the people at tool station, screwfix or Machine Mart) and uses them on Shimano gears sets ( they have JIS fixings) what ever they are !! Quote Link to comment Share on other sites More sharing options...
Bender Posted November 16, 2018 Share Posted November 16, 2018 Nowt wrong with a bit of adative Quote Link to comment Share on other sites More sharing options...
