TomGrainger Posted January 28, 2019 Share Posted January 28, 2019 Hi guys, having my annual "battery's dead, time for a week of pain," period of the year. Battery has charged up fine but when I've gone to put it back in, the nut that holds the hex screw onto the battery terminal has magically vanished. I've no idea how because the one on the other side is pretty firmly wedged into place and I'd bet I would struggle to get it out by force. So I need to be a lonesome little nut before I can fully secure the battery into place. Firstly, im not sure on the size. The mechanics put the battery in after my last failed MOT (whichcamewithlotsofworkimnotsurewasentirelynecessarybutletsleavethatalonefornow) but I know I used a 13mm socket to take the screw off (bit fiddly to get a screwdriver in the space). So I need to know what size nut to go with the screw. Is it as simple as 13mm screw, 13mm nut?Secondly, am I gonna have to buy a pack of 20 and have 19 spares lying around? Thanks guys, I'm a mechanical disaster so any help appreciated. Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 28, 2019 Share Posted January 28, 2019 These nuts are usually rectangular and quite deep so ordinary hexagonal nuts won't work . Have a look on eBay. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 28, 2019 Share Posted January 28, 2019 https://www.ebay.co.uk/p/1-Set-Universal-M5x10mm-Scooter-ATV-Dirt-Bike-Battery-Terminal-Nut-and-Bolt-Kit/21019439684?iid=263699223295&chn=psAlso stop letting your battery go flat otherwise you will be buying a new one Although I suspect some damage has already been done Quote Link to comment Share on other sites More sharing options...
TomGrainger Posted January 28, 2019 Author Share Posted January 28, 2019 Thanks, these are ideal, im just going to have to find some that will deliver quicker wven if I need to pay premium on delivery.As regards to lettinf it go flat its a tough one. I'm constantly bumped from placement to placement in totally different places. Sometimes it's possible to ride others I have to take public transport and then the bike stays stagnant a while. Maybe I should look into a trickle charger. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 28, 2019 Share Posted January 28, 2019 you should get at least 2 months before having to top a battery up with charge even then there would probably be enough juice to start it Quote Link to comment Share on other sites More sharing options...
Via Posted January 28, 2019 Share Posted January 28, 2019 Hex nuts can work but a lot more fiddly getting in, I glued one to a strip of card to get it in and aligned (also had issue that they are thinner so had to be lifted slightly) but the nut itself was big enough it wouldn't turn in the channel when tightened but didn't over tighten just in case.Sizing different matter, head is not bolt size, 13mm is normally an M8... https://www.engineeringtoolbox.com/metric-bolt-head-wrench-size-d_1458.html but that seems large for a bike battery, most I've seen are normally M6,only way to be sure is measure width of actual bolt (threaded part). Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 28, 2019 Share Posted January 28, 2019 Hex nuts can work but a lot more fiddly getting in, I glued one to a strip of card to get it in and aligned (also had issue that they are thinner so had to be lifted slightly) but the nut itself was big enough it wouldn't turn in the channel when tightened but didn't over tighten just in case.Sizing different matter, head is not bolt size, 13mm is normally an M8... https://www.engineeringtoolbox.com/metric-bolt-head-wrench-size-d_1458.html but that seems large for a bike battery, most I've seen are normally M6,only way to be sure is measure width of actual bolt (threaded part).Hex nuts still turn and can wreck the soft terminal blocks that are made of lead . A top tip is to glue the new ones in place with a bit of silicone . I've lost count of how many of these things have disappeared inside my bikes and never fallen out of the bottom onto the ground. Make sure you carefully measure to get the right size . I bought some off eBay recently and I assumed they were a standard size but when they arrived they were way too small. Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 28, 2019 Share Posted January 28, 2019 I've just stumbled upon a YouTube vid that offers a neat and simple way of securing your battery nuts that I'm definitely going to use as soon as I get the chance . Here's two stills , its pretty self explanatory. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 1, 2019 Share Posted February 1, 2019 I am frankly amazed at the restraint shown so far. Has everyone got sensible all of a sudden? Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted February 2, 2019 Share Posted February 2, 2019 It’s a problem that few would experience. Quote Link to comment Share on other sites More sharing options...
fastbob Posted February 2, 2019 Share Posted February 2, 2019 It’s a problem that few would experience. Especially this fine fellow . Quote Link to comment Share on other sites More sharing options...
