Danielloves125 Posted February 3, 2019 Share Posted February 3, 2019 So I own a Kawasaki klx 125 and I've been having this problem for ages, the shock doesn't seem to push the bike back up when it goes down when sitting/pushing it down, its also very hard and not soft.I have tried the following,Changing all the bearings that are linked to the shock and have also got another shock from ebay and changed it and it does the same thing. Any ideas?I can provide a video if needed.Thanks for reading,Daniel. Quote Link to comment Share on other sites More sharing options...
Stu Posted February 3, 2019 Share Posted February 3, 2019 Swing arm bearings? Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted February 3, 2019 Share Posted February 3, 2019 Hello and welcome Quote Link to comment Share on other sites More sharing options...
Bender Posted February 3, 2019 Share Posted February 3, 2019 Is this a first bike?, are you sure your not trying to fix something that's not broke, do you have a comparison? Welcome. Quote Link to comment Share on other sites More sharing options...
fastbob Posted February 3, 2019 Share Posted February 3, 2019 This shock from eBay, maybe it's shagged as well . Does it have adjustable rebound damping and spring preload ? Try setting the damping to minimum and the spring to maximum and work backwards from there . When you had the shock off did everything move freely then ? Errm ..how much do you weigh by the way ? Let's see this video. Quote Link to comment Share on other sites More sharing options...
Danielloves125 Posted February 4, 2019 Author Share Posted February 4, 2019 Thank you everyone for replying, I shall upload a video of the problem soon. Also I have checked the swing arm bearings and they are fine. Quote Link to comment Share on other sites More sharing options...
oldgrump Posted February 4, 2019 Share Posted February 4, 2019 Hi, First off I would slacking the four bolts quite alot on the linkage underneath swingarm, and then see if you can move suspension up and down. and if still no movement undo swingarm bolt. You never said if it's something you brought or you have ridden before? Quote Link to comment Share on other sites More sharing options...
