MWBlake Posted May 2, 2019 Share Posted May 2, 2019 Hello, My 2016 Zontes Tiger 125 3A turns over but doesn't start. The side stand is definitely up, it's defintley petrol in my tank, and the kill switch is definitely not on. Initially my spark was pretty weak, so I got a new one and now get a much stronger spark, but it still doesn't start. The battery in my bike is only 2 months old, and the fluid levels are fine. I tried taking out my carburetor, cleaning it (took jets out etc.) and put it back, still nothing. I tried replacing my coil, still nothing. So what could be next? Stator?Any ideas/advise would be really appreciated. Thanks in advance for ant responses. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted May 2, 2019 Share Posted May 2, 2019 If it's sparking then you need to move away from the electrics and on to the other two things that are needed - is fuel getting into the cylinder and is it being compressed?Is the spark plug wet with fuel when you take it out after it not starting? Quote Link to comment Share on other sites More sharing options...
