Justinat735 Posted May 4, 2019 Share Posted May 4, 2019 I have been working on the electrics on my bike when I was finished and started to tape up I did a check on everything and the indicators have stopped working I have supplied powered to all of them and they all light up but when I flick the switch they don’t come on I have checked the wire inside and along the bike they are all fine I think it might be to do with the resistors any advice on what to do ? Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 4, 2019 Share Posted May 4, 2019 Were they working before you did the work on your electrics ? If they were then it's probably time to start all over again . This sort of thing is too hands on to offer any constructive advice . Good luck. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted May 6, 2019 Share Posted May 6, 2019 You've probably checked this but just in case.....LEDs are polarity sensitive. The last ones I fitted I set up using the multimeter to identify current flow but then they wouldn't work with the ignition on. Turned out current flowed in the opposite direction due to a switched earth when the ignition was on. D'oh! Quote Link to comment Share on other sites More sharing options...
