biglesbo Posted July 12, 2019 Share Posted July 12, 2019 (edited) Hi all Names Les aged 64 havent touched a bike since 1980 Live in a small village and walking is an issue thought to solve the problem with a bikeWaiting for my licence to be returned before commencing CBT Didnt have a big budget (now even smaller ) bought a 2013 LEXMOTO ARIZONA 7,300 KM DONE 40KM SINCE LASAT M O T 2016been garaged and started every week had it 6 weeks------------------------------------------------------New battery but as the battery terminal needs a new connector just connected battery twice a week and started using electric start went to start it last week no starter no green neutral light starts with kickstart and green neutral light comes on----tested battery and tried it on another machine oktried an alternative known working battery and a powerbank no starter no green neutral light -----------------so issue not batterypossibly fuse or earthnon technical dont know how what or where manuel wiring diagram in haynes manuel just coloured lines ----------as ive got to have it M O T would it be expensive to repair or is it an easy fix thnx in advance lesstarting bike https://youtu.be/pDoSjBcsi8g THE QUESTION WOULD BE AS ITS NOT THE BATTERY WHAT WOULDSTOP THE NEUTRAL LIGH AND STARTER SWITCH FROM WORKING ???????????????????????????????????????????????????????????????? Edited July 13, 2019 by biglesbo Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted July 12, 2019 Share Posted July 12, 2019 It is common for these to not show neutral particularly when hot. Unfortunately the bike thinks it is in gear when it doesn't show neutral. just pull the clutch and it should start ok. The batteries appear to be on the small side and if it is slightly under voltage or cold it will only start on the kick. I had one of these and got an Oxford charger for it and then it started every time on first turn.Hope this helpsDave Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted July 12, 2019 Share Posted July 12, 2019 Ps forgot to mention try chinese motor cycle parts.Everything you need and great prices/ service.I had mine over a year and it never let me down just need regular maintenance.Dave Quote Link to comment Share on other sites More sharing options...
biglesbo Posted July 12, 2019 Author Share Posted July 12, 2019 It is either a fuse or an earth problem as stated in origional post not battery as tried with known working battery and powerbank jumper Bike knows when its in neutral as it shows when kickstarted -----------thnx LES Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted July 12, 2019 Share Posted July 12, 2019 Not having a neutral light is not an MOT failure. Also, it doesn't need the engine running to perform the test. Quote Link to comment Share on other sites More sharing options...
biglesbo Posted July 12, 2019 Author Share Posted July 12, 2019 Many thanks for that will not put the battery on when i send to m o t ---Will talk to the garage before sending to see the cost of repair many thanks for taking the time to postregards LES Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted July 13, 2019 Share Posted July 13, 2019 Might be the switchgear in the right hand side. If it is on the originals they are poor quality. As far as I can remember there is only one fuse which is under the seat so in theory if it's blown nothing should work. There is also the starter solenoid under there too. I'd check all the connections as a start then look to the right hand switch. I have just remembered I had the same fault when I first got mine and changed both. Dave Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted July 13, 2019 Share Posted July 13, 2019 Many thanks for that will not put the battery on when i send to m o t You'll need the battery on so they can test the lights etc. Also, if they kick start it, it could damage the electrickery without a battery in the system.Just explain to the tester that the starter isn't working and that they'll need to kick it. Quote Link to comment Share on other sites More sharing options...
biglesbo Posted July 13, 2019 Author Share Posted July 13, 2019 Thanks for tha learning new things constantlythnxMISTAKENLY STATED "ARROW " ITS AN ARIZONA Quote Link to comment Share on other sites More sharing options...
biglesbo Posted July 24, 2019 Author Share Posted July 24, 2019 Bought a "chinese bike " haynes manualwiring diagrams look like a platefull of sphaggeti and dont appear to cover the arizona exactly however located a red fusebox just to the rear of where the battery sits next to i believe the starter unitinside was a broken 20 amp fuse so hopefully once replaced should solve the problemstill waiting for my licscencewill post again Quote Link to comment Share on other sites More sharing options...
biglesbo Posted July 24, 2019 Author Share Posted July 24, 2019 New Fusestarted straight off and neutral light workingmany thanksLes Quote Link to comment Share on other sites More sharing options...
skyrider Posted July 25, 2019 Share Posted July 25, 2019 result Quote Link to comment Share on other sites More sharing options...
lesperkl Posted December 18, 2022 Share Posted December 18, 2022 Back again 3 years no problems Headlights not working why would both bulbs not be working ? ------------------------------------------- friday opened back door 6 pm 1 right hand indicator was on not blinking no key in ignition so obviously not switched om - inserted key started first kick indicators functioned as they should as did hazard function and back brake light however headlight not working - no phantom light since - first thought fuse but wouldnt that stop the other lights from working ?? - just put it in kitchen had to fight the wife to get it in so can now work on her - any advice apreciated Quote Link to comment Share on other sites More sharing options...
