Topbanana0 Posted August 5, 2019 Share Posted August 5, 2019 Ok, so I have a 1989 ZX10 b2.Bike starts ok on the choke, then struggles to tick over unless lots of choke is used.It revs high then when you reduce choke, struggles to run and sounds lumpy.The carbs were sonic cleaned and balanced in 2017, by the previous owner. But unfortunately the bike hasn't been used since.I'm suspecting it's a fuel (carb) issue, where would you start. Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 6, 2019 Share Posted August 6, 2019 Ok, so I have a 1989 ZX10 b2.Bike starts ok on the choke, then struggles to tick over unless lots of choke is used.It revs high then when you reduce choke, struggles to run and sounds lumpy.The carbs were sonic cleaned and balanced in 2017, by the previous owner. But unfortunately the bike hasn't been used since.I'm suspecting it's a fuel (carb) issue, where would you start. Definitely drain the carbs and tank and add fresh fuel . If that has no effect I would pop the tops off the carbs , carefully lift out the slides , needles and diaphragms and clean any sludge off the slides and tracks . Check for holes in the diaphragms while you're at it . I've done this a couple of times when my GSXR was a bit grumpy after being laid up for the winter . Quote Link to comment Share on other sites More sharing options...
TimR Posted August 7, 2019 Share Posted August 7, 2019 check the carb to engine rubbers especially the balancing spigot rubber bung covers ( little brass pipes that stick out of these and have a rubber bung on them these can perish and allow air to weaken the mix hence running on choke Quote Link to comment Share on other sites More sharing options...
Topbanana0 Posted August 7, 2019 Author Share Posted August 7, 2019 check the carb to engine rubbers especially the balancing spigot rubber bung covers ( little brass pipes that stick out of these and have a rubber bung on them Screenshot_20190807-191633_Samsung Internet.jpgthese can perish and allow air to weaken the mix hence running on choke Thanks for the diagram, I'll be getting on it at the weekend Quote Link to comment Share on other sites More sharing options...
Topbanana0 Posted August 11, 2019 Author Share Posted August 11, 2019 So I stripped the carbs, found them to be dirty inside.And two of the pilot jets were blocked.Completely stripped it, cleaned everything.I think the main problem with the bike being laid up, was the fuel tap was/is fault. It wouldn't turn off, the last owner thought he turned it off but fuel was always going to carbs.Anyway bike now runs fine probably going to balance carb in the future.YouTube video might follow soon Sorry about the emoji in last post, I appear to be giving you the finger. Thought it was a thumbs up Quote Link to comment Share on other sites More sharing options...
