Rkel1988 Posted August 19, 2019 Share Posted August 19, 2019 Evening all. Back with another problem! When starting my bike i start it up put my helmet and jacket on gloves etc jump on engage first gear and when i go to pull away it seems to go “flat” stutter then when i change into second its fine also sometimes cuts out if i rev it in first then come to a stop. Once bike is running it seems to be fine albeit the odd cut out at lights when idling. I changed the oil to castrol 10w40 and it needed a new coil pack as well which i have since replaced. Any ideas? P.s its fuel injected Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 hi how old is the bike Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 Sorry its a 2018 done around 6000km Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 strewth that coil didnt last very long Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 (Please dont shout at me) its a mutt mongrel 125cc built in sunny china Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 (edited) but even so you would have thought it would have lasted longer then that its only a year old and 3728 miles Edited August 19, 2019 by skyrider Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 It burnt out when i was gunning down the a1 for about an hour flat out at 60mph Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 when did you last service it plug -filters etc Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 It was last serviced at about 4/5000km i changed the oil when i got it. So only done probably 1500km since last service Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 right so thats nearly a thousand miles, i would start with taking the plug out and give it a clean with a wire brush and check the gap with a feeler gauge Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 Okay will give it a going over tomorrow let you know the result. Cheers for the advice Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 and have a look at the air filter as well Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 Just had a quick look at air filter. Clean as a whistle apart from this oily patch? Cause for concern? Or normal? Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 no i reckon that should be ok for a while Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 ts a big filter though, is it a round one Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 Yeah round and hollow Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 19, 2019 Share Posted August 19, 2019 it looks a big one for a 125 is it standard Quote Link to comment Share on other sites More sharing options...
Rkel1988 Posted August 19, 2019 Author Share Posted August 19, 2019 Yeah standard the bloke who owned before me barely rode it. Quote Link to comment Share on other sites More sharing options...
linuxrob Posted August 21, 2019 Share Posted August 21, 2019 does that spot line up with carb throat?, please check you valve clearance. you should find the spec on the net. It looks like a Suzuki GS125 clone motor.Valve clearance (when cold) GS125 IN.: 0.04-0.07 mm EX.: 0.13-0.18 mmRob B Quote Link to comment Share on other sites More sharing options...
