Kawasakiii Posted September 28, 2019 Share Posted September 28, 2019 Hi all in need of abit of advice got a 1999 kawasaki er5 engine needs too much work for melooking to buy a new engine but can only find half decent ones from 2004 onward models only but unsure if itll fit or not.Any help appreciated Cheers Quote Link to comment Share on other sites More sharing options...
Stu Posted September 28, 2019 Share Posted September 28, 2019 [mention]fastbob[/mention] will be along shortly to give you all the info you could ever need on these bikes! Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted September 28, 2019 Share Posted September 28, 2019 Hi all in need of abit of advice got a 1999 kawasaki er5 engine needs too much work for melooking to buy a new engine but can only find half decent ones from 2004 onward models only but unsure if itll fit or not.Any help appreciated Cheers Where are you based and what needs doing to the engine? There may be some people around your area that are able to help you out with it Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 28, 2019 Share Posted September 28, 2019 Hi all in need of abit of advice got a 1999 kawasaki er5 engine needs too much work for melooking to buy a new engine but can only find half decent ones from 2004 onward models only but unsure if itll fit or not.Any help appreciated Cheers Every ER5 engine will fit every ER5 . See my thread in Old Bikes Projects and Restorations entitled ER5 engine swap . I've actually still got my old engine sitting in my backyard if it's any use to you . One thing to remember when buying ER5 engines is that they cannot be made to change gear when they are not in a moving bike . Anything you want to know about the ER5 , let me know . Quote Link to comment Share on other sites More sharing options...
TimR Posted September 28, 2019 Share Posted September 28, 2019 Gpz500 engines will fit as well Kle500 also Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 28, 2019 Share Posted September 28, 2019 (edited) Gpz500 engines will fit as well Kle500 also The GPZ will fit but you're going to have a hard time fabricating a gear change mechanism . At least I think that's correct but I might be wrong . Edited September 28, 2019 by fastbob Quote Link to comment Share on other sites More sharing options...
Kawasakiii Posted September 28, 2019 Author Share Posted September 28, 2019 Cheers for the help wanna get another er5 engine going to get it professionally fitted had enough of trying to sort old one out Quote Link to comment Share on other sites More sharing options...
Kawasakiii Posted September 28, 2019 Author Share Posted September 28, 2019 Hi all in need of abit of advice got a 1999 kawasaki er5 engine needs too much work for melooking to buy a new engine but can only find half decent ones from 2004 onward models only but unsure if itll fit or not.Any help appreciated Cheers Where are you based and what needs doing to the engine? There may be some people around your area that are able to help you out with itI'm near norwich mate had coolant problems with engine for ages system keeps overpresserising n pissing put of expansion tank done all the external work but no joy engine has gotten really hot a couple of times so dont wanna risk chucking loads of money at it engine was running fine other than the coolant problem apart from couple of days ago so either warped head or gasket or crack in the block Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted September 28, 2019 Share Posted September 28, 2019 Fair enough, hope it gets sorted soon mate Quote Link to comment Share on other sites More sharing options...
