Clive-aliveRR Posted October 8, 2019 Share Posted October 8, 2019 Hi every one I’m just new here, I am seeking some advice on my 2003 Cbr600rr I have just recently serviced the bike and now coincidentally after I have done that the bike seemsTo be lacking in power it’s just not taking off like it did and also the temperature seems to be rising more quickly the fan comes on when it reaches a certain temperature as normal but it just seems to be rising quicker than it did before.. so like I said I just serviced it. I changed the oil, changed the air filter changed the coolant (note: I did not flush the old coolant out of the system I just emptied the reseviour and put new coolant in to it) I thinking I should maybe flush the coolant out of the system could be something to do with that? But that W ouldn’t make the bike loose power would it? The only way I can describe it is that it feels like the bike has been rescricted but it’s not obviously lol, so if anyone has any ideas they’d be greatly appreciated, thanks Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 8, 2019 Share Posted October 8, 2019 Well you haven't really changed the coolant if you have only changed what was in the reservoir ,. Whatever the problem is , if it's occurred after you did a service then it must be something that you have done . You will have to re trace your every step . Quote Link to comment Share on other sites More sharing options...
Bender Posted October 8, 2019 Share Posted October 8, 2019 Temp, lack of coolant/airlock twisted kinked hose, blocked radiator, radiator covered, ignition timing out, head gasket blown, exhaust restricted baffle collapsed Lack of power, air intake issue, blocked exhaust, burnt valves, blocked fuel filter, fuel restriction.The list is endless almost, but as bob said look at what you have done and look for something you may have moved or damaged inadvertently. Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 8, 2019 Author Share Posted October 8, 2019 Thanks guys! Have heard of guys spraying the air filter with a certain oil? I never done this I just replaced it without doing that but I’m assuming that wouldn’t be anything to do with it, I’m pretty sure it’s something to do with the coolant/radiator to be honest but will look at it this week and let use know how I get on I’m hoping it’s a pretty simple problem tho, hopefully nothing to serious like the head gasket :/ Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 8, 2019 Author Share Posted October 8, 2019 Also if there was air in the system how could it have gotten there the only thing I removed was the cap of the reseviour but going to do a proper coolant flush and see where that gets me Quote Link to comment Share on other sites More sharing options...
skyrider Posted October 8, 2019 Share Posted October 8, 2019 just take the top off the water tank and listen for a gurgling of air/water Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 8, 2019 Share Posted October 8, 2019 Flush all the old coolant out, fill up with a fresh 50/50 mix until tank and rad full, then squeeze large tubes repeatedly until bubbles stop rising to top of rad and tank. Run engine to circulate coolant and once cool, squeeze air out again. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 8, 2019 Share Posted October 8, 2019 Thanks guys! Have heard of guys spraying the air filter with a certain oil? I never done this I just replaced it without doing that but I’m assuming that wouldn’t be anything to do with it, I’m pretty sure it’s something to do with the coolant/radiator to be honest but will look at it this week and let use know how I get on I’m hoping it’s a pretty simple problem tho, hopefully nothing to serious like the head gasket :/ K&N filters should be oiled but not ordinary ones . Check to see if you have installed it correctly . Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 9, 2019 Share Posted October 9, 2019 Lack of power with tendency to get hot quickly makes me wonder if it's running lean. Possibly something to do with the installation of the new air filter or maybe you've got the air box assembled wrong and it's leaking air into the system. Quote Link to comment Share on other sites More sharing options...
Harry Posted October 9, 2019 Share Posted October 9, 2019 Good advise above ... recheck what you've done, which I'm guessing you have done by now ... did you replace the spark plugs? always worth rechecking the plugs are the correct ones and gapped correctly ... let us know what you discover. Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 9, 2019 Author Share Posted October 9, 2019 Haven’t checked yet but will do all today thanks for the suggestions guys, funny the thing I dread most is taking the damn fairings on and off. Bloody nightmare to get back on again lol Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 9, 2019 Share Posted October 9, 2019 Haven’t checked yet but will do all today thanks for the suggestions guys, funny the thing I dread most is taking the damn fairings on and off. Bloody nightmare to get back on again lol Which is why , after 20 years of f****g around with lumps of plastic and button head screws that mysteriously disappear , I finally bought a Harley . Quote Link to comment Share on other sites More sharing options...
skyrider Posted October 9, 2019 Share Posted October 9, 2019 Haven’t checked yet but will do all today thanks for the suggestions guys, funny the thing I dread most is taking the damn fairings on and off. Bloody nightmare to get back on again lol yep that's why i don't buy bikes with fairings anymore,hard work to do a service and first thing to smash when you take a tumble Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 10, 2019 Author Share Posted October 10, 2019 Glad I’m not the only one , I have left the bike with a friend who also owns owns a motorcycle repairs shop due to me being to busy with work, so should hopefully know what the problem is soon and shall keep you all updated. He can be the one flinging the fairings about the place now instead of me haha Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 12, 2019 Author Share Posted October 12, 2019 Okay guys it’s looking like it’s a head gasket Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 12, 2019 Share Posted October 12, 2019 That is not good news. Must be just a coincidence it went the same time as you serviced it. The only thing you could do to bust a head gasket would be to get an airlock in the engine which could damage the cylinder head if it overheated. Quote Link to comment Share on other sites More sharing options...
oldgrump Posted October 12, 2019 Share Posted October 12, 2019 If the bike was running fine before you serviced it, then why would the Head Gasket go! I would seriously get a second opinion.I've ridden and worked on bikes all my life and rarely do you see a jap bike with Head Gasket issues.How many miles has this 600 done! But seriously I would get someone like a main dealer to check it, it might be expensive at first, but will save you a lot in the long run. Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 12, 2019 Author Share Posted October 12, 2019 Oldgrump I’m thinking the same also it’s to much of a coincidence there’s something not right with the bike and I don’t think it’s a head gasket either to be honest he is going to do a compression test and a few other things before he jumps In the deep end, the bike has 15,000 miles on it which isn’t a lot for a 2003 bike and it’s not exactly showing any typical head gasket blown signs, only being down on power and temperature rising faster Quote Link to comment Share on other sites More sharing options...
Bender Posted October 12, 2019 Share Posted October 12, 2019 Simple test for poc in water will confirm. Quote Link to comment Share on other sites More sharing options...
TimR Posted October 12, 2019 Share Posted October 12, 2019 So you changed airfilter Have you installed incorrectly ? This could be restricting airflow .If its Choking the engine this can make it get hotter quicker ( leans the air/fuel mixture)Forgot to re attach a pipe ?A bike with an ecu will require a correct temp reading to process a suitable setting so if its registering too hotor cold this could affect performance .You could have a air lock in coolant,If you have ridden it for any great time the this could have caused overheating in areas of the engine .Double check all the work you did ie airfilter and all relevant connections Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 16, 2019 Author Share Posted October 16, 2019 Okays think we found the problem were 95% sure it’s the coils that are bad and makes sense going by the symptoms I’m getting like no acceleration/power in lowers RPMs.. so fingers crossed this is the problem pretty bad timing just after I serviced it Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 19, 2019 Author Share Posted October 19, 2019 Anyone still active here enlighten me on this?.. Okay turns out it wasn’t the coils either, replaced them and still the same but I think I may have figured out what is causing this, it’s the last thing I can think of and it’s something I think we’ve over looked i might be wrong but when I serviced it I got distracted and put to much oil in it.. could this be causing the symptoms I’m having? Quote Link to comment Share on other sites More sharing options...
Bender Posted October 19, 2019 Share Posted October 19, 2019 Excess smoke would-be first sign, put it to correct level and ride it easy enough to rule out. Quote Link to comment Share on other sites More sharing options...
Clive-aliveRR Posted October 19, 2019 Author Share Posted October 19, 2019 There is white smoke comes from the exhaust when started up but stops once it’s warmed up, I’ve read online that having access oil can effect performance/acceleration due to the crank rotating and catching the access oil throwing it around making it frothy and possibly having it go into the air box also, this is my last option cause everything else on the bike has been checked and seems fine, I have a feeling this may be the cause since it’s happened after i serviced it Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 20, 2019 Share Posted October 20, 2019 Well drain the oil, measure what comes out, then refill to the correct level. Check the air filter as well.I'm pretty sure any decent workshop would spot a simple error on service items. The oil level window or dipstick is an easy check. Making sure the air filter is in right only takes a few minutes. In terms of the coolant you said you only drained and refilled the header tank but if there's any doubt drain the system and refill it White smoke from cold is usually only the steam in the exhaust gases condensing. Oil smoke has a blue tinge to it and it lingers in the air longer. Quote Link to comment Share on other sites More sharing options...
