Blondie Posted December 5, 2019 Share Posted December 5, 2019 Hello.The problem that I am experiencing is as follows:My honda CBF 125 starts fine after resting. I ride it and at some point it cuts out. I coast and stop st the side of the road. The engine turns but does not start. There is no spark. I have tried changing the coil. The bike ran for 30 seconds at idle then stopped.I have experienced this twice. The first time I was riding for an hour when it cut out. The second was after 5 minutes.Could it be the ECU/CDI? -how can I check this?(OBD2 port?)Any ideas would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted December 5, 2019 Share Posted December 5, 2019 Stator? They tend to fail as they get hot which matches your symptoms. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted December 5, 2019 Share Posted December 5, 2019 I think early CBFs had a problem with the fuel pump that was just like this? Quote Link to comment Share on other sites More sharing options...
Blondie Posted December 6, 2019 Author Share Posted December 6, 2019 Thanks for your responses, although I dont think this problem is the stator. There is power to run the lights and turn the engine over so I sont think it's the charging system. There could be a fuel problem as well but that doesnt cover why there is no spark. Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted December 6, 2019 Share Posted December 6, 2019 Maybe a few things to check;Spark plug leadSide stand switch faultyIgnition switchTip sensor Quote Link to comment Share on other sites More sharing options...
Copycat73 Posted December 6, 2019 Share Posted December 6, 2019 replace the spark plug Quote Link to comment Share on other sites More sharing options...
Phill Posted December 11, 2019 Share Posted December 11, 2019 [mention]Copycat73[/mention] What he said.I had the same problem one morning, the bike started and then died suddenly, the spark plug died, and it looked alright visually.One new spark plug later, i was off on my way to work! Quote Link to comment Share on other sites More sharing options...
