billy sugger Posted January 13, 2020 Share Posted January 13, 2020 HI all. My bike, a Honda CBf600sa-8 (2008 model) has a dash with two little lcd displays in it, one is a clock (if you look at a pic it is the rh one), and the other is a combination odometer/trip display. Since last Monday the clock display has been blank and the odometer/trip just a set of dashes, and it now has a clock setting on it, though never had before. I removed all the front fairing this weekend to look for a faulty connection or something, but could find nought wrong. I sprayed all connections with cleaner, there were no loose connections and most of the wiring and connectors were in a good clean condition.Anyone any ideas what has happened? my Haynes wiring diagram is basically useless, as it just shows a box with "instrument panel" in it and 16 different coloured wires going into it, but no explanation as to what goes where. The right hand reset button (two little buttons bottom centre of dash) normally sets the clock and activates the HISS anti theft( for programming a new key), and the HISS warning light that flashes when ignition is turned off is also off.This has got me well and truly baffled Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted January 13, 2020 Share Posted January 13, 2020 Have a look at this one may help better, will look at the manual see if I can help. Look at 20-21 in this manual https://www.manualslib.com/download/1068381/Honda-Cbf600sa.htmland Owners manualhttps://www.manualslib.com/manual/1447240/Honda-Cbf600s-2006.html?page=3#manual Quote Link to comment Share on other sites More sharing options...
billy sugger Posted January 14, 2020 Author Share Posted January 14, 2020 Thankyou Mr Pickwick. Will try and make sense of it all at the weekend Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 14, 2020 Share Posted January 14, 2020 Take the whole unit off and stick it on top of a radiator ( central heating variety ) for a day. Sounds like moisture has got in . Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 14, 2020 Share Posted January 14, 2020 Does submerging it in rice or something not also help with drawing out moisture? Quote Link to comment Share on other sites More sharing options...
skyrider Posted January 15, 2020 Share Posted January 15, 2020 you will have it on blotting paper next Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 15, 2020 Share Posted January 15, 2020 you will have it on blotting paper next Didn't think about that Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 15, 2020 Share Posted January 15, 2020 Does submerging it in rice or something not also help with drawing out moisture? I think that might apply to phones but I doubt that would do much good with an instrument console because it has too many internal cavities . Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 15, 2020 Share Posted January 15, 2020 Does submerging it in rice or something not also help with drawing out moisture? I think that might apply to phones but I doubt that would do much good with an instrument console because it has too many internal cavities . Ahh ok that's where iv heard it used Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted January 15, 2020 Share Posted January 15, 2020 I think that might apply to phones but I doubt that would do much good with an instrument console because it has too many internal cavities . If it's left in there long enough then the rice should sap the water out of it.Proper desiccant would work better mind. Quote Link to comment Share on other sites More sharing options...
billy sugger Posted January 16, 2020 Author Share Posted January 16, 2020 I have big desiccant bags in my camera gear so will try them Friday as may be working Saturday Quote Link to comment Share on other sites More sharing options...
