potatobroxd Posted March 31, 2020 Share Posted March 31, 2020 This is one of the wires that connect to the front dash, I'm not sure how to remove it? Thanks for the help Quote Link to comment Share on other sites More sharing options...
fastbob Posted March 31, 2020 Share Posted March 31, 2020 Grip each side firmly with two small pairs of pliers and twist and pull it apart . Alternatively , use a small flat screwdriver and a twisting motion to slightly pry the female connector apart then gently crimp it closed again on reassembly . Quote Link to comment Share on other sites More sharing options...
potatobroxd Posted March 31, 2020 Author Share Posted March 31, 2020 Grip each side firmly with two small pairs of pliers and twist and pull it apart . Alternatively , use a small flat screwdriver and a twisting motion to slightly pry the female connector apart then gently crimp it closed again on reassembly . Thanks, was easier than i thought Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted April 1, 2020 Share Posted April 1, 2020 Grip each side firmly with two small pairs of pliers and twist and pull it apart . Alternatively , use a small flat screwdriver and a twisting motion to slightly pry the female connector apart then gently crimp it closed again on reassembly . Thanks, was easier than i thought You must have done it wrong then. Any seemingly simple job involving motorcycles ought to result in cut hands, broken tools, tantrums and tears.If it seems to go smoothly you haven't understood the enormity of the situation. Quote Link to comment Share on other sites More sharing options...
