hardleydavidson Posted May 30, 2020 Share Posted May 30, 2020 Hi,I'm taking a wild guess here but I think my mixture may be way too high, spark is black and it'll only run smoothly without the air filter, also when I give it some throttle from idle the revs drop instead of increase. Could these all be related to a too high mixture? Quote Link to comment Share on other sites More sharing options...
raesewell Posted May 30, 2020 Share Posted May 30, 2020 Correct, by the sounds of it. Quote Link to comment Share on other sites More sharing options...
WD-40 Posted May 31, 2020 Share Posted May 31, 2020 What bike is it? If you can find a workshop manual, it will tell you what the standard settings are for the carb and you can check what your one is set to. Someone could have adjusted the idle mixture screw or raised the jet needle or increased the jet size Quote Link to comment Share on other sites More sharing options...
hardleydavidson Posted May 31, 2020 Author Share Posted May 31, 2020 Hi It's a Chinese 50cc, more of a toy really. I doubt there's much in the way of a manual out there for it. I do know that it has a PZ19 carb, anyone know what setting the jet needle should be at for sea level in the uk? Quote Link to comment Share on other sites More sharing options...
WD-40 Posted May 31, 2020 Share Posted May 31, 2020 Here's one for pz carbs. Might be of some help. http://www.ccwthariders.com/uploads/9/7/7/9/9779070/pz_carb_tuning_manual.pdfYou would probably need the workshop manual for your model bike to get the exact setting Quote Link to comment Share on other sites More sharing options...
hardleydavidson Posted May 31, 2020 Author Share Posted May 31, 2020 That's awesome thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted May 31, 2020 Share Posted May 31, 2020 You can ever be too rich or too thin. Quote Link to comment Share on other sites More sharing options...
