geofferz Posted June 12, 2020 Share Posted June 12, 2020 My mate's bike started making this noise. I don't think it moves. It's booked into the garage next Wednesday but I don't suppose anyone happens to know a quick and easy fix?! Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 Could be an exhaust leak where the exhaust joins the engine. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 12, 2020 Share Posted June 12, 2020 It does sound exhaust related, but diagnosing via a video clip is never very accurate.If it is exhaust try restrcting the tailpipe with a damp rag and see if it becomes more obvious. Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 As above sounds very exhausty maybe one or more of the exhaust seals is leaking or the collector box maybe Quote Link to comment Share on other sites More sharing options...
geofferz Posted June 12, 2020 Author Share Posted June 12, 2020 I'm informed that it now does not start at all... Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 I'm informed that it now does not start at all... Does it still turn over on the button? Quote Link to comment Share on other sites More sharing options...
geofferz Posted June 12, 2020 Author Share Posted June 12, 2020 Briefly apparently Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 Briefly apparently Then what? Stops dead? runs out of battery! I must say it didn't sound good at all in the video I think its mechanical to be honest Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 There is a hint of mechanical to it but I think it sounds exhausty quite alot too, but as has been said previously it's very difficult to diagnose a video Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 I agree with Stu doesn't sound good. Has a bit of a metal on metal sound. The phone could be picking up the sound coming from the can Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 I agree with Stu doesn't sound good. Has a bit of a metal on metal sound. The phone could be picking up the sound coming from the can Could well be, maybe a top end rebuild on the cards eh Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 [mention]geofferz[/mention] Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 I agree with Stu doesn't sound good. Has a bit of a metal on metal sound. The phone could be picking up the sound coming from the can Could well be, maybe a top end rebuild on the cards eh Don't know. Guess you'd have to open it up and have a look at it. If it was a valve problem would it still idle like it was in the video? Don't think so. Could it be a cam chain tensioner failure and the noise is a mad loose cam chain? That's just a wild guess Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 I agree with Stu doesn't sound good. Has a bit of a metal on metal sound. The phone could be picking up the sound coming from the can Could well be, maybe a top end rebuild on the cards eh Don't know. Guess you'd have to open it up and have a look at it. If it was a valve problem would it still idle like it was in the video? Don't think so. Could it be a cam chain tensioner failure and the noise is a mad loose cam chain? That's just a wild guess But if the cam chain was goosed then it wouldnt run at all because the timing would be that far out within a few revolutions of the engine that it would have cut out there and then and in a big way so if it is mechanical its more likely to be bottom end with oil starvation or a tappet/lifter/bent valve problem top end Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 I agree with Stu doesn't sound good. Has a bit of a metal on metal sound. The phone could be picking up the sound coming from the can Could well be, maybe a top end rebuild on the cards eh Don't know. Guess you'd have to open it up and have a look at it. If it was a valve problem would it still idle like it was in the video? Don't think so. Could it be a cam chain tensioner failure and the noise is a mad loose cam chain? That's just a wild guess I must admit it does sound very tappety If it is oil starvation it could easily wear the cam lobes and rockers etc Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 @geofferz Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 @geofferz Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading In that case if it's not been checked would that be a warranty void? Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 My mate's bike started making this noise. I don't think it moves. It's booked into the garage next Wednesday but I don't suppose anyone happens to know a quick and easy fix?! What can is he running on it? Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 @geofferz Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Yeah I saw one with 4200 miles on the clock and it had blown up! Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 12, 2020 Share Posted June 12, 2020 @geofferz Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Yeah I saw one with 4200 miles on the clock and it had blown up! that's ludicrous, why would they sell it with an engine that uses so much oil surely triumph should have ironed that out in testing.....and I thought that british bikes were just mean to leak the oil from various gaskets/seals rather than eat it Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 @geofferz Has he checked the oil level? There is a history of these drinking oil then the engine blowing up Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Yeah I saw one with 4200 miles on the clock and it had blown up! That's shocking. You'd think they would have to give a refund if it only lasted 4200 miles. Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Yeah I saw one with 4200 miles on the clock and it had blown up! that's ludicrous, why would they sell it with an engine that uses so much oil surely triumph should have ironed that out in testing.....and I thought that british bikes were just mean to leak the oil from various gaskets/seals rather than eat it I heard the CBR1000 burned some ridiculous amount of oil and Honda said it was normal so it does happen Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 Did a quick google search there and you're right. There's lots of examples of engine blowing up. Doesn't make for good reading Yeah I saw one with 4200 miles on the clock and it had blown up! That's shocking. You'd think they would have to give a refund if it only lasted 4200 miles. Yeah I would expect a new engine at the very least and a bike to ride while its in Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12, 2020 Share Posted June 12, 2020 Yeah I saw one with 4200 miles on the clock and it had blown up! that's ludicrous, why would they sell it with an engine that uses so much oil surely triumph should have ironed that out in testing.....and I thought that british bikes were just mean to leak the oil from various gaskets/seals rather than eat it I heard the CBR1000 burned some ridiculous amount of oil and Honda said it was normal so it does happen Yeah they claimed 1 litre of oil per 1000 miles was OK Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 12, 2020 Share Posted June 12, 2020 that's ludicrous, why would they sell it with an engine that uses so much oil surely triumph should have ironed that out in testing.....and I thought that british bikes were just mean to leak the oil from various gaskets/seals rather than eat it I heard the CBR1000 burned some ridiculous amount of oil and Honda said it was normal so it does happen Yeah they claimed 1 litre of oil per 1000 miles was OK If you went for a weekend away you'd have to bring a litre or two with you The R1 had a lot of problems too. https://www.bikebandit.com/blog/how-yamaha-s-massive-r1-recall-is-an-opportunity-in-disguise I think BMW have had problems too. Quote Link to comment Share on other sites More sharing options...
