Parky Posted June 22, 2020 Share Posted June 22, 2020 Hi all Hope someone can help out...I have a 1999 xj600s that I’m trying to get up and running Have given the carbs a good clean out , float heights in spec , valve clearances in spec...Put back on the bike and it started straight away so let her warm up , but she sounded a bit lumpy felt the headers and number 1 cylinder is cold only running on 3Pulled the plug it is producing a good strong spark although it did look and feel dry.Any ideas would be much appreciated where to start looking firstFuel , electrical, mechanical!All of the above.. Quote Link to comment Share on other sites More sharing options...
Bender Posted June 22, 2020 Share Posted June 22, 2020 If its dry I would look at fuel again for that cylinder Quote Link to comment Share on other sites More sharing options...
Parky Posted June 22, 2020 Author Share Posted June 22, 2020 YesCouldn’t remove the drain screw on carb 1 to check, will have to remove carbs again.. Quote Link to comment Share on other sites More sharing options...
