Woodsman_pagan Posted June 24, 2020 Share Posted June 24, 2020 So I've been having problems with my cbr 125 for about a month now.I've replaced the battery, cleaned up the earth, found and replaced a female connection that was corroded connecting to the regulator rectifier, I've also replaced the regulator. Once I had done this it seemed to work just fine. But now again will not start. Battery is charged, have tried to bump start it to not avail. This is my only mode of transport unfortunately Quote Link to comment Share on other sites More sharing options...
Tiggie Posted June 24, 2020 Share Posted June 24, 2020 Welcome to the forum Are you getting a spark from the plugs? I'd check that first off all, see if they are wet as well to make sure fuel is getting to them Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted June 24, 2020 Share Posted June 24, 2020 What voltage does it charge at? I'd be worried about the stator too.. Quote Link to comment Share on other sites More sharing options...
