sam11189 Posted July 12, 2020 Share Posted July 12, 2020 Hey Folks basically fitted aftermarket indicators on my bike..and ye as above they all blink at same time..so i fitted the diodes to prevent current crossing over to the other side amd they still blinks 4 ways only when i signal right!i dont understand how the current is getting through the diode...when i signal left there no problems but when i signal right all 4 blinks. so ive no idea.. any ideas folkscheers Quote Link to comment Share on other sites More sharing options...
Marino Posted July 12, 2020 Share Posted July 12, 2020 Some people still use them Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted July 12, 2020 Share Posted July 12, 2020 Are the indicators LED, if so you may need resistors or an indicator unit that is for LEDS. Quote Link to comment Share on other sites More sharing options...
WD-40 Posted July 12, 2020 Share Posted July 12, 2020 Are you trying to add a 4 way switch or are you just trying to install indicators? The only way I can see that they would all blink is you joined the right and left together some how. Did you take the indicator switch apart? Quote Link to comment Share on other sites More sharing options...
Guest Swagman Posted July 12, 2020 Share Posted July 12, 2020 Did you connect to the hazard switch?. Quote Link to comment Share on other sites More sharing options...
fastbob Posted July 12, 2020 Share Posted July 12, 2020 Take it all apart and start again using a wiring diagram . Regardless of whether these things require diodes , they have to be connected wrong to all flash at the same time . Quote Link to comment Share on other sites More sharing options...
WD-40 Posted July 13, 2020 Share Posted July 13, 2020 I don't think a 2001 R6 has a hazard switch. He might have been trying to add one. A LED is a diode so there's no reason to be adding another diode to an LED. He's either messed up the wiring connections and joined the two sides together, or he's taken the indicator switch apart and messed it up or he's trying to add a hazard switch. I think as fastbob says whatever you've done take it apart and start again. Quote Link to comment Share on other sites More sharing options...
