Beans Posted September 9, 2020 Share Posted September 9, 2020 My torque wrench goes up to 60NM, but my rear wheel nuts need 70. So I guess I am off to Halfords to buy a second torque wrench. I have my eye on the one that goes to 100NM. https://www.halfords.com/tools/hand-tools/spanners-and-wrenches/halfords-advanced-torque-wrench-model-100-488703.htmlIs there anything anywhere on a bike that has a higher torque setting than the rear wheel nuts? Quote Link to comment Share on other sites More sharing options...
WD-40 Posted September 9, 2020 Share Posted September 9, 2020 Yes is the answer. Some need more than 100Nm but the 60Nm will do the job for most bolts. Have a look at the torque values in the service manual. There's usually a page in the near the start that lists all the various torques. https://www.carlsalter.com/triumph-service-manuals.asp Quote Link to comment Share on other sites More sharing options...
Gerontious Posted September 9, 2020 Share Posted September 9, 2020 When you look at torque values always bear in mind that any fixing that may be contaminated with oil, the torque reduces by about 30%. It’s important to remember this or you risk stripped threads.As for the actual question, I bought a 40-200nm Quote Link to comment Share on other sites More sharing options...
Beans Posted September 9, 2020 Author Share Posted September 9, 2020 Thanks. Looks like I will get similar to yours, [mention]Gerontious[/mention] Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 9, 2020 Share Posted September 9, 2020 My torque wrench goes up to 60NM, but my rear wheel nuts need 70. So I guess I am off to Halfords to buy a second torque wrench. I have my eye on the one that goes to 100NM. https://www.halfords.com/tools/hand-tools/spanners-and-wrenches/halfords-advanced-torque-wrench-model-100-488703.htmlIs there anything anywhere on a bike that has a higher torque setting than the rear wheel nuts? For goodness sake , just nip it up so it doesn't come undone . Quote Link to comment Share on other sites More sharing options...
Beans Posted September 9, 2020 Author Share Posted September 9, 2020 Eh? Quote Link to comment Share on other sites More sharing options...
skyrider Posted September 9, 2020 Share Posted September 9, 2020 with a spanner Quote Link to comment Share on other sites More sharing options...
Beans Posted September 9, 2020 Author Share Posted September 9, 2020 Yes, thanks. Still think I will stick with the manufacturers recommended torque settings, using a torque wrench. Hence the original question Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted September 9, 2020 Share Posted September 9, 2020 Yes, thanks. Still think I will stick with the manufacturers recommended torque settings, using a torque wrench. Hence the original question Just bear in mind that those torque figures are meant for brand new and perfectly clean threads unless specified otherwise. That is, no your dirty rear axle and used nut doesn't need the book spec and no the used sump plug, non-OEM washer and aluminium threads now covered in oil also doesn't need the book spec. It just needs doing up enough so it won't come undone.I use a 5-25Nm torque wrench more than a big one because the bolts for cam caps, coated in fresh oil like the book says, need to be right. Great big rusty/greasy fasteners on the chassis aren't nearly as picky. Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 9, 2020 Share Posted September 9, 2020 Yes, thanks. Still think I will stick with the manufacturers recommended torque settings, using a torque wrench. Hence the original question Just bear in mind that those torque figures are meant for brand new and perfectly clean threads unless specified otherwise. That is, no your dirty rear axle and used nut doesn't need the book spec and no the used sump plug, non-OEM washer and aluminium threads now covered in oil also doesn't need the book spec. It just needs doing up enough so it won't come undone.I use a 5-25Nm torque wrench more than a big one because the bolts for cam caps, coated in fresh oil like the book says, need to be right. Great big rusty/greasy fasteners on the chassis aren't nearly as picky. I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft . Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted September 9, 2020 Share Posted September 9, 2020 I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft .Why pound-inch?GSXR manual says 8-12 Nm which is fairly standard for an M6 fastener in grade 8.8 and well within range of small torque wrenches.More damage most likely from dirty or damaged threads and inaccurate torque wrenches that are never calibrated. Quote Link to comment Share on other sites More sharing options...
husoi Posted September 10, 2020 Share Posted September 10, 2020 The bolts on my towbar hitch are fastened to 220Nm but they are ginormous Quote Link to comment Share on other sites More sharing options...
TimR Posted September 10, 2020 Share Posted September 10, 2020 If you desire a torque wrench buy it and use it Other people's opinions are just that and saying you don't need one is their personal view . Example ...I could hand someone a chainsaw and ask them to sharpen it for softwood felling ... Something i can easily do freehand ... But 99% of people would require file guides and depth guides . Does it detract from the outcome ? No Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 10, 2020 Share Posted September 10, 2020 I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft .Why pound-inch?GSXR manual says 8-12 Nm which is fairly standard for an M6 fastener in grade 8.8 and well within range of small torque wrenches.More damage most likely from dirty or damaged threads and inaccurate torque wrenches that are never calibrated.Ok , when I get home from work I'll dig out my GSXR manual and have a look . Quote Link to comment Share on other sites More sharing options...
husoi Posted September 10, 2020 Share Posted September 10, 2020 I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft . Why pound-inch?GSXR manual says 8-12 Nm which is fairly standard for an M6 fastener in grade 8.8 and well within range of small torque wrenches.More damage most likely from dirty or damaged threads and inaccurate torque wrenches that are never calibrated.Ok , when I get home from work I'll dig out my GSXR manual and have a look .I would struggle to calculate things in imperial. there are 1,000's of websites that will convert pretty much anything into metric so if your torque wrench is metric you can always convert itJust an example:https://onlineconversion.com/torque.htm Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted September 11, 2020 Share Posted September 11, 2020 In too many decades of spannering I have wrecked things by over tightening. Worst case was a classic model aircraft engine I broke the crankshaft collet on by overdoing the prop nut. But I have never had anything nipped up tight that has come loose.Engine rebuilds I use a torque wrench on camshaft journals because it's a surprisingly low setting. Bigger things I work on the basis if it feels right it's not going to fall off. Always worth checking after a few miles of course. Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 11, 2020 Share Posted September 11, 2020 In too many decades of spannering I have wrecked things by over tightening. Worst case was a classic model aircraft engine I broke the crankshaft collet on by overdoing the prop nut. But I have never had anything nipped up tight that has come loose.Engine rebuilds I use a torque wrench on camshaft journals because it's a surprisingly low setting. Bigger things I work on the basis if it feels right it's not going to fall off. Always worth checking after a few miles of course. You're preaching to the converted as far as I'm concerned but there are those among us who obviously love using torque wrenches . Maybe they ride their bikes thinking " Well it's not my fault if something falls off because the Torque Wrench said it was ok " Quote Link to comment Share on other sites More sharing options...
Tiggie Posted September 11, 2020 Share Posted September 11, 2020 I've been hand tightening the wheel nuts on my wife's cars for years without worrying about torque settings Quote Link to comment Share on other sites More sharing options...
WD-40 Posted September 11, 2020 Share Posted September 11, 2020 If you're doing engine work you need one. If you buy the tool and do the work yourself instead of paying a mechanic to do it the torque wrench pays for itself on the first job. Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted September 11, 2020 Share Posted September 11, 2020 If you're doing engine work you need one. If you buy the tool and do the work yourself instead of paying a mechanic to do it the torque wrench pays for itself on the first job. Very true Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 29, 2020 Share Posted September 29, 2020 I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft .Why pound-inch?GSXR manual says 8-12 Nm which is fairly standard for an M6 fastener in grade 8.8 and well within range of small torque wrenches.More damage most likely from dirty or damaged threads and inaccurate torque wrenches that are never calibrated.I don't know either . I've no idea where I got that idea from . Must be going daft . Quote Link to comment Share on other sites More sharing options...
Mickly Posted September 29, 2020 Share Posted September 29, 2020 I've been hand tightening the wheel nuts on my wife's cars for years without worrying about torque settings Just finger tight Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 29, 2020 Share Posted September 29, 2020 I've been hand tightening the wheel nuts on my wife's cars for years without worrying about torque settings Just finger tight You're wasting your time . There are Torque Wrench believers and there are Torque Wrench non believers and neither faction will be persuaded otherwise . The non believers probably had Meccano and the believers probably had Playstation when they were kids . Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted September 29, 2020 Share Posted September 29, 2020 If you never bother to get your torque wrench calibrated - it becomes just another long-handled spanner. Quote Link to comment Share on other sites More sharing options...
WD-40 Posted September 29, 2020 Share Posted September 29, 2020 Yes, thanks. Still think I will stick with the manufacturers recommended torque settings, using a torque wrench. Hence the original question Just bear in mind that those torque figures are meant for brand new and perfectly clean threads unless specified otherwise. That is, no your dirty rear axle and used nut doesn't need the book spec and no the used sump plug, non-OEM washer and aluminium threads now covered in oil also doesn't need the book spec. It just needs doing up enough so it won't come undone.I use a 5-25Nm torque wrench more than a big one because the bolts for cam caps, coated in fresh oil like the book says, need to be right. Great big rusty/greasy fasteners on the chassis aren't nearly as picky. I totally get where you're coming from but I don't think our mutual friend will be convinced . Bear in mind that you should use a tiny little torque wrench in INCH pounds to avoid over tightening cam caps . There's many a GSXR and the like been ruined because someone couldn't believe how LITTLE torque is needed to hold down a camshaft . So they ruined their GSXR because they didn't use a torque wrench? Quote Link to comment Share on other sites More sharing options...
