Lumor_uk Posted September 14, 2020 Share Posted September 14, 2020 So I'm trying to put this thing back together after removing the top lower bush. Won't go back in, now I remember thinking bushes need pressing back in. Am I right in thinking it needs a special tool of which I'll never use again? For clarity I can't get the oil seal back on because this bush isn't sitting flush. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted September 14, 2020 Share Posted September 14, 2020 Are you sure it doesn't just need some gentle percussive persuasion? Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 14, 2020 Share Posted September 14, 2020 Can you utilise the old fork seal to help tap it into place ? Quote Link to comment Share on other sites More sharing options...
TimR Posted September 14, 2020 Share Posted September 14, 2020 Can you utilise the old fork seal to help tap it into place ?Or the old bush with the fork washer inbetween the bushesTape around the stanchion so you minimise risk of hitting it Using a flat punch or similar tap around to drive it inwards . Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted September 15, 2020 Author Share Posted September 15, 2020 hum, I chucked the old bush will have a look around my many bits and bobs Quote Link to comment Share on other sites More sharing options...
Guest Swagman Posted September 15, 2020 Share Posted September 15, 2020 A fork seal tool comes in handy, you have to slip the washer in then tw-t it with the side hammer seal insert tool or plastic pipe of some kind, it has to be knocked flush for the seal to fit, don’t try knocking the fork seal in before you seat the bush as the seal just won’t go down properly. Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 15, 2020 Share Posted September 15, 2020 Have a look through the kitchen cupboards and see if you have any Swartz herbs and spices . I seem to recall that the plastic containers make an excellent fork bush driver provided the diameter is right . Next time you do this job measure carefully to make sure the bush is actually the right one . If the other one is seated though there's probably no need . I just wouldn't want you bashing away when it's already fully seated . Quote Link to comment Share on other sites More sharing options...
skyrider Posted September 15, 2020 Share Posted September 15, 2020 Are you sure it doesn't just need some gentle percussive persuasion? do you mean whack it with a hammer Quote Link to comment Share on other sites More sharing options...
