Mr Fro Posted July 12, 2020 Share Posted July 12, 2020 (edited) Next up in the track day clear out are my diamond tyre warmers. I thought I bought these only a couple of years back but the label says 2016 so I must be mistaken! Anyway, I've used these once only so they're pretty much as new condition. No tears, wearing, burns or damage - just a bit of fluff from the carpet. I plugged them in to check they work and they're absolutely spot on, they click on and off just as they should.The front is standard 120: The rear is 180 - 190, what you'll find on most 600ish sports bikes: If you've looked at warmers then you'll know Diamond are about the best. I plugged them in to a little genny and used them between sessions and the difference compared to going out on cold tyres was fantastic!A set of these new will set you back about £225. I'm asking £170 so a decent saving considering they've only been used the once.Cheers,Fro Edited August 7, 2020 by Mr Fro Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted July 22, 2020 Author Share Posted July 22, 2020 Next up in the track day clear out are my diamond tyre warmers. I thought I bought these only a couple of years back but the label says 2016 so I must be mistaken!20200712_170237.jpgAnyway, I've used these once only so they're pretty much as new condition. No tears, wearing, burns or damage - just a bit of fluff from the carpet. I plugged them in to check they work and they're absolutely spot on, they click on and off just as they should.The front is standard 120:20200712_170355.jpg20200712_170418.jpg20200712_170450.jpgThe rear is 180 - 190, what you'll find on most 600ish sports bikes:20200712_170300.jpg20200712_170335.jpg20200712_170508.jpgIf you've looked at warmers then you'll know Diamond are about the best. I plugged them in to a little genny and used them between sessions and the difference compared to going out on cold tyres was fantastic!A set of these new will set you back about £225. I'm asking £170 so a decent saving considering they've only been used the once.Cheers,Fro Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted July 22, 2020 Author Share Posted July 22, 2020 How about £150 - that's a third off! Quote Link to comment Share on other sites More sharing options...
