Guest Posted October 9, 2017 Share Posted October 9, 2017 For geared bikes employing Derbi EBS050 / EBE050 / D50B0 / D50B1 engines.Most aftermarket exhausts are designed with 2-piece header manifolds for the sake of quicker exhaust removal, and isolating vibration to prevent manifold cracking. That design isn't necessary. Not even Viton O-rings teamed with hi-temp copper silicone sealant withstand perishing.Here's a few aftermarket exhausts with 1-piece header manifold design that doesn't leak fuel/oil all over engine cases, or damage the rider's eardrums.Pedmoto SG-1http://www.adrenalin-pedstop.co.uk/upload/images/b8c94-SG1.jpgMetrakit SP3http://rollerhaendler.scooter-attack.com/media/catalog/product/cache/41/small_image/600x/17f82f742ffe127f42dca9de82fb58b1/m/k/mk871d1631_01_1.jpgPromaThe Proma's manufactured a few millimeters too long, so you'll have to make a bracket for the OEM muffler's hanger.Or use one of these mufflers: Giannelli 34683HF. Arrow 52604SUWhich exhaust is most suitable?Depends which characteristics you prefer.Pedmoto: mid range - high rpm power.Metrakit: high rpm power with gutless low - mid range torque.Proma: low-mid range rpm torque monster.High rpm - more explosive power?Narrow power bands only give useful momentum with an 11T front sprocket and 19 - 24mm flat slide carbs. That's useless on public roads, and you'd have to skip 1st gear.TipUse 6mm star washers on header manifold bolts. Quote Link to comment Share on other sites More sharing options...
