satansmeerkat Posted November 3, 2014 Share Posted November 3, 2014 I've hit another wall with my xv 535 project.I can't get the carbs back into place. They won't fit over the rubber seals for the engine and air box. Is there a trick to it, or is it a case of loosening the rubber and brute force and ignorance.I've got the carbs all together, should I take some bits off before I put them into place?Any advice or educated guesses welcome Cheers guys Quote Link to comment Share on other sites More sharing options...
Guest Posted November 3, 2014 Share Posted November 3, 2014 Try WD40 on the rubber or some such stuff. Even water and washing up liquid should help. Or try warming the rubber first with a hair dryer. But just get them warm not hot. Quote Link to comment Share on other sites More sharing options...
satansmeerkat Posted November 4, 2014 Author Share Posted November 4, 2014 Thanks Gautrek, Vaseline worked in the end (I find it always helps when sliding things into rubber ifyouknowwhatimean)However the top rubber seals from the air filter don't quite reach down far enough to fit over the carb intake pipes. Do I just stretch them down, or again, is there some trick? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted November 4, 2014 Share Posted November 4, 2014 They are usually too long - are you sure they are mounted in the air filter unit correctly? Quote Link to comment Share on other sites More sharing options...
satansmeerkat Posted March 1, 2015 Author Share Posted March 1, 2015 It's been a while, I've been very very busy lately and started work again a week ago. Finally got them in, electrics and fuel sorted and now she turns over. Clutch is kinda funny though, I've taken a look and posted it under a new topic Quote Link to comment Share on other sites More sharing options...
Stu Posted March 1, 2015 Share Posted March 1, 2015 Thanks Gautrek, Vaseline worked in the end (I find it always helps when sliding things into rubber ifyouknowwhatimean) I have just seen this vaseline is petroleum based and will eat away at rubber over time!! if your going to use anything a silicone based lube is best or WD40 Quote Link to comment Share on other sites More sharing options...
