Classickid21 Posted November 26, 2015 Share Posted November 26, 2015 Kawasaki er5 a3 carbs standardset up Just ordered a manual I had it runnibg and revving but cut of so i took it apart and try to set it to standard still no joys Newbie to big bikes Help !?!?!? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 26, 2015 Share Posted November 26, 2015 what do you call set to standard???? Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted November 26, 2015 Author Share Posted November 26, 2015 "> I done this this but didn't help :/ its the moment that banging my head against the wall lol i won't give up. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 27, 2015 Share Posted November 27, 2015 so you have had the carbs off the bike and done a basic set up ?if so did you remove float bowls and check all the jets were clear and the float heights for opening and closing off? did you mess with the mixture screws on the sides of the carbs at all if you did then to set them to basic setting screw them all the way in and then back out about 1 1/2 turns each.also for setting the carbs like in that videa personally i would use feeler gauges as that way it is far more accurate but you still need to finalise the setting with the bike running and a set of vacuum gauges Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted November 28, 2015 Author Share Posted November 28, 2015 Hello again I could only get the left hand float bowl of the right hand one has three rounded screws i am taken the carb back off in the week as i ordered a manual and ill take some pictures thank you for all the help Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 28, 2015 Share Posted November 28, 2015 use a small chisel and hammer to give the edge of the screws a tap it should shock them loose then once out replace them with new ones Quote Link to comment Share on other sites More sharing options...
