Classickid21 Posted March 3, 2016 Share Posted March 3, 2016 (edited) Happy days bike passed with flying colours Edited March 10, 2016 by Classickid21 Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 3, 2016 Author Share Posted March 3, 2016 BROUGHT A SPARE FOR £45,00 Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 3, 2016 Share Posted March 3, 2016 BROUGHT A SPARE FOR £45,00Bargain!! Get it fitted and back for a free retest Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 3, 2016 Share Posted March 3, 2016 update your other post then its a nightmare when posts are in different areas about the same things Quote Link to comment Share on other sites More sharing options...
Stu Posted March 3, 2016 Share Posted March 3, 2016 you only need one post!! Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 3, 2016 Author Share Posted March 3, 2016 BROUGHT A SPARE FOR £45,00Bargain!! Get it fitted and back for a free retestindeed sir, my old man told me how gutless the bike was .... how would i remove a restrictor kit ? or is it restricted on a cdi Quote Link to comment Share on other sites More sharing options...
whitedevil Posted March 3, 2016 Share Posted March 3, 2016 It will have large washers between the airbox and carbs, inside the rubbers. Just take them out. My ex500 had them when i bought it the bike wouldnt go over 90mph and had no power band. Much nicer when they were out. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 4, 2016 Share Posted March 4, 2016 It will have large washers between the airbox and carbs, inside the rubbers. Just take them out. My ex500 had them when i bought it the bike wouldnt go over 90mph and had no power band. Much nicer when they were out.the er5 dont go much over 90 at the best of times but will be smoother and a bit quicker getting there unrestricted Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 4, 2016 Author Share Posted March 4, 2016 It will have large washers between the airbox and carbs, inside the rubbers. Just take them out. My ex500 had them when i bought it the bike wouldnt go over 90mph and had no power band. Much nicer when they were out.the er5 dont go much over 90 at the best of times but will be smoother and a bit quicker getting there unrestricted If i recall, when i had the carbs off there was no discs spacers, i might leave it alone it runs snd rides okay, the acceration is bit poor from what the old man states ( up and down the private lane seems fine) Up hill bit sluggish ? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 4, 2016 Share Posted March 4, 2016 now its had a decent run (providing you have been sitting letting it tick over for ages again) pull a spark plug out and check the colour of it to see how its running it might need a bit of adjusting but you also have to rev them fairly well to get them going if i remember correctly Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 4, 2016 Author Share Posted March 4, 2016 now its had a decent run (providing you have been sitting letting it tick over for ages again) pull a spark plug out and check the colour of it to see how its running it might need a bit of adjusting but you also have to rev them fairly well to get them going if i remember correctly Usually let it tick over and warm up 10/15 min's. Thank you for that bit of information, i will pull it out Monday/tuesday. Hopefully the wheel will be with us by then, last set of plugs were bit naffed was running rich. I hadn't tuch it since because it was running like a gem. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 5, 2016 Share Posted March 5, 2016 now its had a decent run (providing you have been sitting letting it tick over for ages again) pull a spark plug out and check the colour of it to see how its running it might need a bit of adjusting but you also have to rev them fairly well to get them going if i remember correctly Usually let it tick over and warm up 10/15 min's. Thank you for that bit of information, i will pull it out Monday/tuesday. Hopefully the wheel will be with us by then, last set of plugs were bit naffed was running rich. I hadn't tuch it since because it was running like a gem.its no good pulling them after its been sat idling it needs to have hada run so its getting fuel fed into the engine from the main jets not the slow running ones hence giving it a run down the road for the mot or something similar and then check plug colour Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 6, 2016 Author Share Posted March 6, 2016 now its had a decent run (providing you have been sitting letting it tick over for ages again) pull a spark plug out and check the colour of it to see how its running it might need a bit of adjusting but you also have to rev them fairly well to get them going if i remember correctly Usually let it tick over and warm up 10/15 min's. Thank you for that bit of information, i will pull it out Monday/tuesday. Hopefully the wheel will be with us by then, last set of plugs were bit naffed was running rich. I hadn't tuch it since because it was running like a gem.its no good pulling them after its been sat idling it needs to have hada run so its getting fuel fed into the engine from the main jets not the slow running ones hence giving it a run down the road for the mot or something similar and then check plug colour Once the wheel has arrived and been fitted ill be ReBooking it MOT. Ill get the old man to give it run down the MOT station and back, ill then check the color and go from there ill update you guys soon Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 9, 2016 Author Share Posted March 9, 2016 Yay! Wheel arrived!!! Just giving the bearings good clean and grease packed. Tomorrow morning. Erny will be pulled out and dismantled and resembled, then rebooked for MOT after the test Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 10, 2016 Author Share Posted March 10, 2016 Update- wheel cleaned bearings greased fitted tested ready for MOT booked for 5 tonight. Fingers crossed Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 10, 2016 Author Share Posted March 10, 2016 Passed the MOT so happy!!!!!! Now its time to sell I have been looking at bandit 600!! Or school boy dream yamaha rd350 Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 10, 2016 Share Posted March 10, 2016 why not use the money to pass your test then get the pleasure of riding something instead of getting someone else to ride anything over 125 for you Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted March 10, 2016 Author Share Posted March 10, 2016 I was just speaking to my partner about this, just now looks like its going to be the plan. Quote Link to comment Share on other sites More sharing options...
