ER5 Engine Swap / Build
Message
Author
fastbob
Gender: Male
Bike(s): gsxr1100 wp and er5
Has Liked: 2211 times
Been Liked: 1678 times
#1 Post by fastbob » Tue Aug 07, 2018 8:01 pm
Ok, I've taken delivery of my £50 " Bargain " ER5 engine . I haven't decided exactly what I'm going to do with it yet . It mostly depends on if I can determine whether the gearbox works or not . ER5s have a peculiarity that means they will not change from first to second unless they are in drive mode and moving . The seller apparently didn't know this and sold it dirt cheap in the belief that it was knackered. My assistant Bob has examined the engine and has given his approval to proceed . Either that or some other moggy has pissed on it .
User avatar
Mr Fro
Gender: Male
Bike(s): ZX6r, ZXR750L Turbo
Has Liked: 30 times
Been Liked: 855 times
Re: ER5 Engine Swap / Build
#2 Post by Mr Fro » Tue Aug 07, 2018 9:52 pm
Don't think it's just the ER5, I've not had a Kwak that'll go straight to second.
Shame it's short as you could have made a go-kart or something.
User avatar
Ricky
Gender: Male
Bike(s): MT-07
Has Liked: 115 times
Been Liked: 117 times
#3 Post by Ricky » Tue Aug 07, 2018 10:05 pm
:stupid:
Made my kwak ninja 250 a bitch to bump start :evil:
Live forever or die trying.
fastbob
Gender: Male
#4 Post by fastbob » Tue Aug 07, 2018 10:13 pm
I seem to recall that my old Z1000 ST would go into second because many's the time I had to scoot it down the drive to start it .
User avatar
Mr Fro
Gender: Male
Has Liked: 30 times
#5 Post by Mr Fro » Wed Aug 08, 2018 7:46 am
:stupid:
You try doing it with a 636: run, puff, run, puff, jump on, dump clutch, skiiiiid... Shit.
User avatar
Mississippi Bullfrog
Gender: Male
Bike(s): Honda CBF500 ABS Triumph Bobber
Has Liked: 319 times
Been Liked: 881 times
#6 Post by Mississippi Bullfrog » Wed Aug 08, 2018 7:47 am
Nah - Bob's just thinking how much cat food you could have bought for the price of a chunk of metal.
If you're doing a take it bits, put it back together, hide the bits left over thread - then lots of piccies please. I love engine builds.
Honda CBF500 ABS
Triumph Bobber
fastbob
Gender: Male
#7 Post by fastbob » Wed Aug 08, 2018 8:56 am
63 tins worth to be precise.
User avatar
Speedy23
Gender: Male
Bike(s): Yamaha FJR 1300A
Has Liked: 192 times
Been Liked: 579 times
#8 Post by Speedy23 » Wed Aug 08, 2018 9:35 am
Cat order of priorities: Me, Me, Me, Me, stick person who supplies food......
Oh my God, what's happened? I don't know man...I just got here myself!
User avatar
Hoggs
Moderator
Gender: Female
Bike(s): ZX-6R
Has Liked: 3095 times
Been Liked: 2459 times
#9 Post by Hoggs » Wed Aug 08, 2018 8:33 pm
:stupid:
Both of these :lol: My ninja won't go into 2nd when stationary either
NOT SIGNED UP FOR THE 2019 CHALLENGE?! WHAT'S WRONG WITH YOU?! DO IT DO IT DO IT NOW viewtopic.php?f=12&t=68681
ImageStopping you having fun since 2017
fastbob
Gender: Male
#10 Post by fastbob » Wed Aug 08, 2018 9:00 pm
We'll I've spun the clutch by hand while trying to shift gears but it isn't looking good . Next job will be to scrape off 19 years worth of chain lube so I can get into the shift mechanism. Never mind its just a bit of fun , I've got all winter to build an engine out of the best ( least worse ) of the two . The one I've bought has a good primary chain in it which is worth way more than £ 50 alone .
User avatar
JRH
The Hoggfather!
Gender: Male
Bike(s): Bandit1250
Challenge Score: 230
Has Liked: 757 times
Been Liked: 955 times
#11 Post by JRH » Thu Aug 09, 2018 7:36 am
My GPX would only go into second gear when the rear wheel was moving, so rather than turning the clutch have you tried turning the drive cog.
Current Bandit 1250 :D
Previous GP125 GSX250 GT750(had 2) GPX750
2019 challenge 100
Pubs 10 / 10
West Midlands 5 / 12
East Midlands 0 / 12
Dealers 2 / 10
Tracks 1/ 20
fastbob
Gender: Male
#12 Post by fastbob » Thu Aug 09, 2018 11:50 am
I see what you mean. I have all the plates out and I'm spinning the inner hub which is slowly rotating the rear sprocket in first . So far I haven't been able to get any other gears but this is by no means conclusive.
User avatar
Gender: Male
#13 Post by Mississippi Bullfrog » Fri Aug 10, 2018 7:38 am
What does Bob think? After all, he's clearly the key played in this process.
Honda CBF500 ABS
Triumph Bobber
fastbob
Gender: Male
#14 Post by fastbob » Sat Aug 11, 2018 8:25 am
Bob's lost interest , I borrowed a Haynes manual from the library and every time I try to read it he comes and sits on it .
fastbob
Gender: Male
#15 Post by fastbob » Sat Aug 11, 2018 8:39 am
A quick update, despite the crusty exterior everything internal is absolutely mint so far . I've had the sump off and there were no metal particles at all and surprisingly little sludge . From here I can see most of the gearbox and again it looks mint , no chipped teeth or worn dogs . The external shifter mechanism is in good order so I am beginning to suspect that the fault lies in the grooves in the selector drum . I seem to be able to get neutral and SECOND rather than neutral and FIRST as I initially thought. So next job is going to be to split the cases and do some inspecting and measuring . The good news is that there are loads of selector drums and whole gearboxes on eBay for very little money.
