ER5 Engine Swap / Build
Message
Author
User avatar
Via
Gender: Male
Bike(s): Sinnis Max II / ER5
Has Liked: 703 times
Been Liked: 512 times
Re: ER5 Engine Swap / Build
#76 Post by Via » Wed Oct 10, 2018 10:35 pm
Stu wrote:
Wed Oct 10, 2018 9:38 pm
Via wrote:
Wed Oct 10, 2018 4:27 pm
Usual answer... Slowly healing, getting to stage I can see improvements now so all good, next question is how much longer will I get away with working from home :lol:
And the grass? :lol:
It's October, grass cutting season is over! :lol:
Hoggs wrote:
Fri Jul 27, 2018 7:21 pm
I agree totally with @Slowlycatchymonkey
fastbob
Gender: Male
Bike(s): gsxr1100 wp and er5
Has Liked: 2189 times
Been Liked: 1663 times
#77 Post by fastbob » Sat Oct 20, 2018 3:39 pm
Ok , stage one , when you tackle a job of this size it's important to label all the gubbins that comes off the bike . Like this .
User avatar
Via
Gender: Male
#78 Post by Via » Sat Oct 20, 2018 4:07 pm
And all the tools you could possibly need for the job :thumb:
fastbob
Gender: Male
#79 Post by fastbob » Sat Oct 20, 2018 5:12 pm
And that's how you do that ! I couldn't get any proper assembly tape so I had to use masking tape , with poor results as you can see.
User avatar
Speedy23
Gender: Male
Bike(s): Yamaha FJR 1300A
Has Liked: 190 times
Been Liked: 572 times
#80 Post by Speedy23 » Sat Oct 20, 2018 5:52 pm
Man, when you gonna learn that going off half-assed gets you nowhere? I mean, you went to the trouble of getting the correct nut removal tool (on the floor by Bob) to remove the engine and then you go and spoil the ship by using masking tape?????
Minus 1 Ichiban Moto sticker for you, dude! Seriously only Bad-1/2-ass!!!!!
Oh my God, what's happened? I don't know man...I just got here myself!
TimR
Gender: Male
Has Liked: 27 times
Been Liked: 440 times
#81 Post by TimR » Sat Oct 20, 2018 5:56 pm
missed one
The woods are lovely, dark and deep,
But I have promises to keep,
And miles to go before I sleep,
And miles to go before I sleep.
Robert Frost
fastbob
Gender: Male
#82 Post by fastbob » Sat Oct 20, 2018 6:01 pm
missed one
Missed what Tim ? No image, dead link . Now I've got it 😆😆😆
User avatar
Tango
Moderator
Gender: Male
Bike(s): Triumph Speed Triple 1050, CB750 Project bike
Challenge Score: 20
Has Liked: 1633 times
Been Liked: 1235 times
#83 Post by Tango » Sat Oct 20, 2018 7:01 pm
Completely unrealistic.........not a Swiss army knife to be seen!....... :wink: :lol: :lol:
I feel the need....the need for Speed......Triple
User avatar
linuxrob
Gender: Male
Bike(s): Suzuki GSF1200S Bandit, GS125. Z500 from new
Has Liked: 29 times
Been Liked: 37 times
#84 Post by linuxrob » Sat Oct 20, 2018 9:54 pm
What a fantastic read.
Need to think of the best/easiest way to repaint the Z500 motor. Should (I hate that word) get the cases, head, and barrels etc vapour or soda blasted, lots of masking off then paint individually.
The ex-rail worker in me says de-grease, brass wire brush, scotch-brite, etch primer then satin black, finally satin lacquer while assembled loosely. Then buff up - re-plate bolts and strip paint off covers. touched up the valve cover a few years ago like this and acetone took the paint off the bolts in a flash.
Anyhoo, made a start on the switch gear today, see post on old bikes restoration thread.
viewtopic.php?f=87&t=68312
I see your assistant Bob stealing the show again.
Rob
User avatar
Via
Gender: Male
#85 Post by Via » Sat Oct 20, 2018 11:38 pm
I think you'll find Bob assists the cat.
fastbob
Gender: Male
#86 Post by fastbob » Sun Oct 21, 2018 3:33 pm
Bob IS the cat 🐱
fastbob
Gender: Male
#87 Post by fastbob » Sun Oct 21, 2018 3:44 pm
Just doing a bit of fettling on the cooling system and discovered that my thermostat has been rattling around loose in its housing for what looks like ages . This could explain why my bike was taking a bit longer to warm up because coolant could get past it even when closed . I can only assume that this has been caused by vibration because the thermostat body doesn't move . I've fixed it by fashioning a large , narrow washer from the lid of a lunch box. Took ages to do but it has done the trick. Strange . ( pic to follow )
TimR
Gender: Male
Has Liked: 27 times
#88 Post by TimR » Sun Oct 21, 2018 5:20 pm
the thermostats normally had a rubber sealing ring around outside edge .
https://www.wemoto.com/parts/picture/fs-24n0446
or i presume by re reading you mean the actual central valve
Robert Frost
fastbob
Gender: Male
#89 Post by fastbob » Sun Oct 21, 2018 10:29 pm
That's right, the actual valve assembly had been rattling around so much that it had formed a lip on the recess it sits in and it had been knocking away at the pointed brass tip of the temperature sensor. To be fair this engine did have a wicked vibration which is one reason its been swapped.
User avatar
Via
Gender: Male
#90 Post by Via » Sun Oct 21, 2018 10:44 pm
I could have printed you one :thumb:
