Honda CD250 fuel tank noise
Message
Author
painter
Been Liked: 1 time
#1 Post by painter » Mon Sep 10, 2018 10:26 pm
Hey guys,
I've just got a £400 Honda CD250U as a fixer-upper, and I'm pretty happy with it so far, although it's now got a weird noise that seems to be getting worse. It sounds like a wire or something metallic tapping on the underneath of the fuel tank intermittently mostly when accelerating, although I can't see loose wire, and it's not regular enough to be something loose. It's like a cross between a tapping, scraping and clicking if that makes any sense? Also can hear it if I take a speed bump a bit too liberally, as the bike's coming back down?
To the untrained ear (this is my first bike!) it seems like it's when the bike pulls away and bits might be moving about and scraping maybe?
It's kind of hard to describe, just wondering if someone has had something like this before...
Cheers!
mikestrivens
Bike(s): Triumph Tiger 800 XCx 2015
Has Liked: 817 times
Been Liked: 920 times
Re: Honda CD250 fuel tank noise
#2 Post by mikestrivens » Mon Sep 10, 2018 10:41 pm
Hello and welcome. Perhaps it's the float in the tank that has come loose and is tapping the inside of the tank. But only a wild guess.
Regards
Mike Strivens
Bikes:
Triumph Tiger 800 XCx, 2015,
used to have Honda VFR800 & Harley Fatboy
Cars:
Mercedes SL500 R129 V8 (1999); Mercedes E320 W124 S6 (1995); Mercedes S600 W140 V12 (1995).
User avatar
Speedy23
Gender: Male
Bike(s): Yamaha FJR 1300A
Has Liked: 206 times
Been Liked: 627 times
#3 Post by Speedy23 » Tue Sep 11, 2018 7:18 am
Anti-slosh baffle round the filler neck come loose? I had this happen on a Guzzi tank. Only way to repair is to cut the tank open and weld. Specialist job. Make sure by draining tank, take it off, remove all the removables and then give it a good shake. If there's anything loose in there you will hear it rattling about.
Oh my God, what's happened? I don't know man...I just got here myself!
User avatar
Mr Fro
Gender: Male
Bike(s): ZX6r, ZXR750L Turbo
Has Liked: 34 times
Been Liked: 922 times
#4 Post by Mr Fro » Tue Sep 11, 2018 7:37 am
I had an odd noise on the ZXR fuel tank - it turned out to be a clearance thing. I had all sorts of odd noises - clunks, screeches - all sorts.
It turned out the mounts were past their best - bosched on some new ones and job done.
fastbob
Gender: Male
Bike(s): Harley Davidson 1200 Roadster and er5
Has Liked: 2559 times
Been Liked: 2157 times
#5 Post by fastbob » Tue Sep 11, 2018 1:18 pm
We'll I don't want to spoil your day but I would be turning my attention to the camchain by now . As I recall the valve cover is only secured by two bolts and it has a reusable seal so you could whip it off and rotate the engine with a ratchet to see if the camchain is uniformly tensioned . Do make sure you turn it the right way and take the plugs out to make it easier . If the camcain goes slack and then goes tight again with a click this could explain your noise .
fastbob
Gender: Male
#6 Post by fastbob » Tue Sep 11, 2018 1:43 pm
I had one of these , I'm pretty sure it didn't have a fuel gauge.
painter
Been Liked: 1 time
#7 Post by painter » Tue Sep 11, 2018 2:50 pm
Aye you're right, no fuel gauge.
painter
Been Liked: 1 time
#8 Post by painter » Tue Sep 11, 2018 8:29 pm
Thanks for the ideas lads, can't take a look until the weekend, hopefully something doesn't blow until then :lol:
fastbob
Gender: Male
#9 Post by fastbob » Wed Sep 12, 2018 9:38 am
Let's have some photos.
