homemade baffles
Message
Author
oldmadbiker
Gender: Male
Bike(s): r1200gs....er500 chop/bobber
Been Liked: 4 times
homemade baffles
#1 Post by oldmadbiker » Wed Sep 12, 2018 8:25 pm
hi all....ive got a bike with straight thru pipes and there way too loud...
the problem i have is there both bent about 3 inch from the end..so ill have problems fitting a baffle in..
so what i was thinking is making baffles with 22mm copper pipe....and bending them to fit around the bend...
that way i might get a baffle 7inch long....
anybody think of a better idea...is copper pipe ok to use...
if i was in america it wouldnt be a problem cos ive seen baffles over there which are flexible made for bent pipes...
ive recently ordered stuff from the usa and with the exchange rate and post it cost me a fortune so want to avoid ordering anything else from there..
cheers all
OwenN
Gender: Male
Bike(s): none at present
Been Liked: 1 time
Re: homemade baffles
#2 Post by OwenN » Wed Sep 12, 2018 9:04 pm
You can buy an internal stub pipe baffle on ebay UK.
This is not legal for inspection purposes, but is a little quieter than open pipes.
https://www.ebay.co.uk/b/Exhaust-Baffle ... n_55196138
a good selection.
Some have a built-in bend.
User avatar
megawatt
Gender: Male
Bike(s): Fazer 1000, GSX1100ET
Has Liked: 726 times
Been Liked: 537 times
#3 Post by megawatt » Wed Sep 12, 2018 9:41 pm
I wouldn't use copper in your exhaust, in can produce poisonous fumes. Use stainless, perforated tube wrapped with fibreglass.
Bike work, I come to you and you can learn to do it yourself click the link below for more info
http://themotorbikeforum.co.uk/viewtopi ... 5&p=949652
oldmadbiker
Gender: Male
Been Liked: 4 times
#4 Post by oldmadbiker » Fri Sep 14, 2018 6:34 pm
cheers.....taking the pipes off this weekend so ill measure the id and see what i can find .
gonna try some baffles of ebay....already got the matting...
cheers
