Honda 1986 CG125
Message
Author
Kwaker
Has Liked: 2 times
Honda 1986 CG125
#1 Post by Kwaker » Sun Oct 14, 2018 4:58 pm
Hi I need a bit of help I've just been given an old recked cg125 1986 model that I want to restore I'm looking for a cylinder head and I've located one (second hand) but the seller is saying it's off a 6 volt bike and mines a 12 volt what difference if any is there ? Thanks in advance
Meggark
Gender: Male
Has Liked: 18 times
Been Liked: 80 times
Re: Honda 1986 CG125
#2 Post by Meggark » Sun Oct 14, 2018 7:32 pm
I'd just get a Chinese barrel and piston set of eBay. In fact that's exactly what I plan to do for mine after winter.
fastbob
Gender: Male
Bike(s): Harley Davidson 1200 Roadster and er5
Has Liked: 2559 times
Been Liked: 2157 times
#3 Post by fastbob » Sun Oct 14, 2018 7:37 pm
No difference at all.The tappet covers were a slightly more angular shape on the Brazilian models but everything is interchangeable . I've built engines from a mixture of models in the past with no problems. If you need any bits let me know. I know CGs inside out so I'm happy to help with any advice as well . Here's few I made earlier.
fastbob
Gender: Male
#4 Post by fastbob » Mon Oct 15, 2018 8:11 am
Are you going to fit a 150 cc kit ? ( I won't tell anyone ) 🤐
fastbob
Gender: Male
#5 Post by fastbob » Mon Oct 15, 2018 8:14 am
He's after a cylinder head .
Kwaker
Has Liked: 2 times
#6 Post by Kwaker » Tue Oct 16, 2018 9:04 am
Thanks for all the replies. I've already sourced a new barrel and piston (keeping it a 125) because as I've said the top end was completely destroyed I will get some pics of the damage later. The piston was holed and one valve head had broken off which in turn damaged the bore beyond repair. Amazingly the crank and Conrod and bearings all seem fine.
By the way I am after a decent exhaust for it if anyone has got one let me know and how much you want for it. Cheers
User avatar
learningtofly
Gender: Male
Bike(s): 2016 BMW R9T
Has Liked: 397 times
Been Liked: 441 times
#7 Post by learningtofly » Tue Oct 16, 2018 9:12 am
My first bike some 38 years ago, so I have a soft spot for these. Good luck with the build.
Kwaker
Has Liked: 2 times
#8 Post by Kwaker » Tue Oct 16, 2018 9:30 am
My first bike ( not counting the nasty Vespas) was a James 197 Villiers engine in 1967 but eventually I did progress to the more reliable non leaking Honda's my first being a Honda benly 125 supersport (fantastic fun) first bike in England under 250 to achieve 100 mph
