Metal oxidation help
Message
Author
Vaderham
Been Liked: 1 time
#1 Post by Vaderham » Sat Dec 08, 2018 11:27 pm
Hi all!
This is my first post here, pleased to meet you all.
I'm after a bit of advice. I'm a bit of an amateur mechanic and have come into an old Yamaha XJ650 that has spent some years out in the weather here in Wellington, New Zealand.
As a result, the engine and rear drum brake housing are pretty extensively oxidised. I understand this will never be returned to it's former glory, but I'm wondering if anyone has encountered this before and how you went about remedying the problem to make it a tad more sightly?
Seems there are mixed opinions around on the best way to handle this, so looking for some first hand advice. Many thanks!
You can see some photos here (WARNING: The bike is in a bad way!)
mikestrivens
Bike(s): Triumph Tiger 800 XCx 2015
Has Liked: 817 times
Been Liked: 912 times
Re: Metal oxidation help
#2 Post by mikestrivens » Sun Dec 09, 2018 10:20 am
Hello, can't see photos
Regards
Mike Strivens
Bikes:
Triumph Tiger 800 XCx, 2015,
used to have Honda VFR800 & Harley Fatboy
Cars:
Mercedes SL500 R129 V8 (1999); Mercedes E320 W124 S6 (1995); Mercedes S600 W140 V12 (1995).
User avatar
Bender
Gender: Male
Has Liked: 472 times
Been Liked: 951 times
#3 Post by Bender » Sun Dec 09, 2018 11:12 am
Hi
If they are bad your probably best off with them removed and properly cleaned and anodised or coated, there is a limit as to what you can do with them on the bike, also pics no worky
Bite my shiny, metal ass!
fastbob
Gender: Male
Bike(s): gsxr1100 wp and er5
Has Liked: 2189 times
Been Liked: 1663 times
#4 Post by fastbob » Sun Dec 09, 2018 4:14 pm
Scotchpads , lots of hard work and high temperature paint . See my before and after pics from my ER5 Engine Swap thread . See also the BMW restoration thread by Wollyjumperuk right here below your post . Welcome to the forum.
fastbob
Gender: Male
#5 Post by fastbob » Sun Dec 09, 2018 4:28 pm
Another approach on things like fork legs or foot peg hangers is to achieve a brushed alloy effect, again by using Scotchpads but working in one direction . Once done , fully degrease with brake cleaner then spray clear lacquer for a lasting finish.
Vaderham
Been Liked: 1 time
#6 Post by Vaderham » Sun Dec 09, 2018 7:32 pm
Woah, Fastbob, those results speak for themselves. Seems like there won't be any shortcuts here. Will just need to spend the time and effort.
Thanks heaps for your advice thus far.
Has anyone tried this product? http://www.acf-50.co.uk/motorcycle.htm
User avatar
Bender
Gender: Male
#7 Post by Bender » Sun Dec 09, 2018 7:36 pm
Just about every one on here that rides through the winter.
mikestrivens
#8 Post by mikestrivens » Sun Dec 09, 2018 7:40 pm
Yes we all use ACF-50 to keep the corrosion at bay.
Regards
Mike Strivens
Bikes:
Cars:
fastbob
Gender: Male
#9 Post by fastbob » Sun Dec 09, 2018 9:29 pm
Happy to help . The trick here is to achieve the best finish possible before painting. It has to be so good that it's almost a shame to paint it. Scotchpads work well when used with water and detergent.
