shamg Posted March 7, 2020 Share Posted March 7, 2020 Was wondering if anyone can help, currently rebuilding an 87 MZ ETZ 250 and all has gone well aside from the clutch. The clutch is assembled and fitted and so is the left hand case and its components. However, when I pull the clutch cable and the retaining arm slides out of the worm, it feels as though it is not making contact with the clutch assembly as there is no pressure. Any suggestions would be very helpful as this is the only thing stopping the bike from working 100%! Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted March 8, 2020 Share Posted March 8, 2020 Have you got this configuration Quote Link to comment Share on other sites More sharing options...
shamg Posted March 10, 2020 Author Share Posted March 10, 2020 Thank you I did not, but I seem to have everything in place stated there, could clutch plates possibly be sticking or something? The bike had been sat a while when I bought it Quote Link to comment Share on other sites More sharing options...
Gsx750f boy Posted March 12, 2020 Share Posted March 12, 2020 Was wondering if anyone can help, currently rebuilding an 87 MZ ETZ 250 and all has gone well aside from the clutch. The clutch is assembled and fitted and so is the left hand case and its components. However, when I pull the clutch cable and the retaining arm slides out of the worm, it feels as though it is not making contact with the clutch assembly as there is no pressure. Any suggestions would be very helpful as this is the only thing stopping the bike from working 100%!hello fellow mz owner.did u adjust plate with 3 screws correctly? Quote Link to comment Share on other sites More sharing options...
shamg Posted March 14, 2020 Author Share Posted March 14, 2020 Yes I did, I also tightened them enough so that I knew the adjustment plate was not spinning, will have another play around with it over the course of the weekend. Quote Link to comment Share on other sites More sharing options...
shamg Posted March 21, 2020 Author Share Posted March 21, 2020 Okay a bit of progress, I have got the clutch semi working, however it does not stop the back wheel spinning entirely. Only a combination of pressing the rear brake and pulling the clutch causes the back wheel to stop spinning, is this a sign of any particular fault such as stuck plates? The bike is currently on a bike stand with the back wheel in the air. Quote Link to comment Share on other sites More sharing options...
JRH Posted March 21, 2020 Share Posted March 21, 2020 On the centre stand the wheel will often rotate due to drag on the clutch. When you operate the rear brake and the wheel stops and the engine does not stall all is generally well. Quote Link to comment Share on other sites More sharing options...
shamg Posted March 22, 2020 Author Share Posted March 22, 2020 Oh that’s a relief, now I’ll just have to wait for god knows how long for a new clutch cable to arrive on a quick side note I also pulled a bunch of horse hair out of the exhaust which I assume is the fibreglass muffler. Do I need to replace the exhaust, or does it have no impact on performance Quote Link to comment Share on other sites More sharing options...
fastbob Posted March 22, 2020 Share Posted March 22, 2020 Oh that’s a relief, now I’ll just have to wait for god knows how long for a new clutch cable to arrive on a quick side note I also pulled a bunch of horse hair out of the exhaust which I assume is the fibreglass muffler. Do I need to replace the exhaust, or does it have no impact on performance It has very little impact on performance despite it being huge and despite the bike being a Two-stroke . I ran a TS 125 with a silencer off a Honda that I found in a ditch and on one occasion with no silencer at all . Quote Link to comment Share on other sites More sharing options...
