Ericc1995 Posted April 4, 2020 Share Posted April 4, 2020 Hi, i have split the cases today and got a look at the gearbox and have spotted the reason mine was probably stuck in gear. I will upload some pictures and hopefully someone can confirm and also advise me if they would change the oil spray pipe as it looks like it's has a bit of bash.Also the main sprocket has been welded on loose!! Oil spray pipe ruined? Loosely welded sprocket Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted April 4, 2020 Share Posted April 4, 2020 Jeez, not a lot of teeth left on that sprocket, def change the pipe, how's the selectors Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted April 4, 2020 Share Posted April 4, 2020 Lol That sprocket looks like the sort of thing Bruce Lee would sling around in a kung fu film.CheersIan Quote Link to comment Share on other sites More sharing options...
Ericc1995 Posted April 4, 2020 Author Share Posted April 4, 2020 Lol That sprocket looks like the sort of thing Bruce Lee would sling around in a kung fu film.CheersIan Selectors are fine but the replacement gearbox is off a low mileage model and it comes with the forks, cam and shift rod aswell. Quote Link to comment Share on other sites More sharing options...
Ericc1995 Posted April 4, 2020 Author Share Posted April 4, 2020 Lol That sprocket looks like the sort of thing Bruce Lee would sling around in a kung fu film.CheersIan Selectors are fine but the replacement gearbox is off a low mileage model and it comes with the forks, cam and shift rod aswell. Sorry meant for the guy above you lol Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted April 4, 2020 Share Posted April 4, 2020 Can you see what caused the damage to the spray bar?I remember the loose sprocket nut was a feature for the model, I loctited mine on. Quote Link to comment Share on other sites More sharing options...
